Help to wire something
Hello everyone, hope your all having a great day. So I'm doing a science project and k need to make a electric quiz board( of you don't know it's easier to just google it). So I have to add a led which is mandatory. But you can get bonus marks if you add extra stuff like buzzers etc. I added a active buzzer and it worked fine. And then I tried the passive buzzer but it's hard to work with because the led stays on all the time or follows the buzzers pattern or only the buzzer works and not the led. Can you guys help me wire it? Thanks in advance.
Well we need to see how you have wired it already then we can tell you where you went wrong with your homework. Otherwise just giving you the wiring is like cheating on your homework by doing it for you.
So post a schematic and post your code because it is more likely that your code is the problem.
Linkuru:
just google it
You have some fundamental misunderstanding of how Google works. My Google is not your Google. It knows where I am and what I have searched in the past. There are different advertisers who want to sell me different things to what they want to sell to you. It will give me different results. Please just tell us what it is or give a direct link to a page with a simple photo or explanation. Wikipedia is good for that.
Without a schematic of what you have wired, it is impossible to help. And there is a problem with the code you didn't post. (I didn't post the description of the problem.)
#include "pitches.h"
// notes in the melody:
int melody[] = {
NOTE_C4, NOTE_G3, NOTE_G3, NOTE_A3, NOTE_G3, 0, NOTE_B3, NOTE_C4
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations[] = {
4, 8, 8, 4, 4, 4, 4, 4
// iterate over the notes of the melody:
pinMode(8, OUTPUT);
  pinMode(7, OUTPUT);
    digitalWrite(7, HIGH);
  for (int thisNote = 0; thisNote < 8; thisNote++) {
  // to calculate the note duration, take one second divided by the note type.
  //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
  int noteDuration = 1000 / noteDurations[thisNote];
  tone(8, melody[thisNote], noteDuration);
  // to distinguish the notes, set a minimum time between them.
  // the note's duration + 30% seems to work well:
  int pauseBetweenNotes = noteDuration * 1.30;
  delay(pauseBetweenNotes);
  // stop the tone playing:
  noTone(8);
the code is this one
and the pitches.h code is
* Public Constants
#define NOTE_B0  31
#define NOTE_C1  33
#define NOTE_CS1 35
#define NOTE_D1  37
#define NOTE_DS1 39
#define NOTE_E1  41
#define NOTE_F1  44
#define NOTE_FS1 46
#define NOTE_G1  49
#define NOTE_GS1 52
#define NOTE_A1  55
#define NOTE_AS1 58
#define NOTE_B1  62
#define NOTE_C2  65
#define NOTE_CS2 69
#define NOTE_D2  73
#define NOTE_DS2 78
#define NOTE_E2  82
#define NOTE_F2  87
#define NOTE_FS2 93
#define NOTE_G2  98
#define NOTE_GS2 104
#define NOTE_A2  110
#define NOTE_AS2 117
#define NOTE_B2  123
#define NOTE_C3  131
#define NOTE_CS3 139
#define NOTE_D3  147
#define NOTE_DS3 156
#define NOTE_E3  165
#define NOTE_F3  175
#define NOTE_FS3 185
#define NOTE_G3  196
#define NOTE_GS3 208
#define NOTE_A3  220
#define NOTE_AS3 233
#define NOTE_B3  247
#define NOTE_C4  262
#define NOTE_CS4 277
#define NOTE_D4  294
#define NOTE_DS4 311
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_FS4 370
#define NOTE_G4  392
#define NOTE_GS4 415
#define NOTE_A4  440
#define NOTE_AS4 466
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_CS5 554
#define NOTE_D5  587
#define NOTE_DS5 622
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_FS5 740
#define NOTE_G5  784
#define NOTE_GS5 831
#define NOTE_A5  880
#define NOTE_AS5 932
#define NOTE_B5  988
#define NOTE_C6  1047
#define NOTE_CS6 1109
#define NOTE_D6  1175
#define NOTE_DS6 1245
#define NOTE_E6  1319
#define NOTE_F6  1397
#define NOTE_FS6 1480
#define NOTE_G6  1568
#define NOTE_GS6 1661
#define NOTE_A6  1760
#define NOTE_AS6 1865
#define NOTE_B6  1976
#define NOTE_C7  2093
#define NOTE_CS7 2217
#define NOTE_D7  2349
#define NOTE_DS7 2489
#define NOTE_E7  2637
#define NOTE_F7  2794
#define NOTE_FS7 2960
#define NOTE_G7  3136
#define NOTE_GS7 3322
#define NOTE_A7  3520
#define NOTE_AS7 3729
#define NOTE_B7  3951
#define NOTE_C8  4186
#define NOTE_CS8 4435
#define NOTE_D8  4699
#define NOTE_DS8 4978
Please edit your post and use </> code tags.
Most people that use the forum try to respect the guidelines that will get better answers.
Sorry about that I didn't know that's what your supposed to do.
MorganS:
I’ve used that example code in the past.
If you followed the instructions, it’s pretty hard to get wrong.
The example is intended to drive a simple speaker from the chosen output pin (possibly amplified through a transistor).
It won’t work with most ‘buzzers’ as they require a different drive method - and often generate the tone within the buzzer.
You may be able to find an instructable (urgh!) that uses a similar method - which will help you get the basics working.
All that sketch does, is shake the output pin at various frequencies (with the tone() ) function. The speaker turns those voltage changes into sound you can hear,
What do you mean instructables?
Back to Google again.
Linkuru:
Instructable is a crap web site where idiots post stuff. However if you know more than the idiots you might pick up some good ideas but never try to learn fundamental stuff from it.
Oh ok. But regarding the schematic can I give you a picture?
Post #7 tells you everything you need.
If you can’t get past that, i’m sorry but you need to go back a few steps, and practice with the very basics, blinking LED etc...
Instructables certainly isn’t the font of all knowledge, but if you know nothing, it can help you gain some understanding of simple concepts - then run away from it as fast as you can!
Can you explain why the circuit works with a normal buzzer but when I add a passive buzzer the led is dimmer and follows the tone of the buzzer? Is it because their is not enough power?
Ok so it's done and it worked. I didn't change the code either. So basically I added a nte2321. And that solves the problem. And now the light bulb will stay on solid and the buzzer will follow the code.
Yay! Good perseverance - I hope you learned a lot.
Cheers!
Sorry for being terse, but you did it yourself!
