Help toggling a relay via a TFT screen
added that to the code, now get the following error
"expected primary-expression before '==' token" this is on the line below where shown again
i know its me, just cant figure this bit out, and its winding me up.
#include <TouchScreen.h>
#include <Adafruit_GFX.h>    // Core graphic library
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <Wire.h>
#define MINPRESSURE 200
#define MAXPRESSURE 1000
const int relay1 = 53;       // output for relay - LEFT SIDE LIGHTS
const int relay2 = 51;       // output for relay - RIGHT SIDE LIGHT
const int relay3 = 49;       // output for relay - LEFT INDICATOR
const int relay4 = 47;       // output for relay - RIGHT INDICATOR
const int relay5 = 45;       // output for relay - BRAKE LIGHTS
const int relay6 = 43;       // output for relay - FOG LIGHT
const int relay7 = 41;       // output for relay - SPARE...
const int relay8 = 39;       // output for relay - SPARE...
#define FLASH_ON 600                                  //  delay between FLASHES
#define FLASH_OFF 500                                 //  delay between FLASHES
#define NUM_FLASH 8                                   // Number of Flashes for Indicators
#define ON 5000                                       // test time delay
#define SIDEON = true;
const int XP = 8, XM = A2, YP = A3, YM = 9; //320x480 ID=0x9486
const int TS_LEFT = 129, TS_RT = 887, TS_TOP = 949, TS_BOT = 97;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
Adafruit_GFX_Button SIDE_btn, SIDEON_btn, BRAKE_btn, LIND_btn, RIND_btn, FOG_btn, RSIDE_btn, LSIDE_btn;
int pixel_x, pixel_y;     //Touch_getXY() updates global vars
bool Touch_getXY(void)
  TSPoint p = ts.getPoint();
  pinMode(YP, OUTPUT);      //restore shared pins
  pinMode(XM, OUTPUT);
  digitalWrite(YP, HIGH);   //because TFT control pins
  digitalWrite(XM, HIGH);
  bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
  if (pressed) {
    pixel_x = map(p.x, TS_LEFT, TS_RT, 0, tft.width()); //.kbv makes sense to me
    pixel_y = map(p.y, TS_TOP, TS_BOT, 0, tft.height());
  return pressed;
//                                      R    G    B
#define BLACK           0x0000      //   0,   0,   0
#define RED             0xF800      // 255,   0,   0
#define WHITE           0xFFFF      // 255, 255, 255
#define ORANGE          0xFD20      // 255, 165,   0
#define GREEN           0x0F00      //   0, 255,   0
void setup(void)
  Wire.begin();
  pinMode(relay1, OUTPUT);        // SET RELAY AS OUTPUTS
  pinMode(relay2, OUTPUT);
  pinMode(relay3, OUTPUT);
  pinMode(relay4, OUTPUT);
  pinMode(relay5, OUTPUT);
  pinMode(relay6, OUTPUT);
  pinMode(relay7, OUTPUT);
  pinMode(relay8, OUTPUT);
  digitalWrite(relay1, HIGH);     // SET AS HIGH AT POWER UP (OFF)
  digitalWrite(relay2, HIGH);
  digitalWrite(relay3, HIGH);
  digitalWrite(relay4, HIGH);
  digitalWrite(relay5, HIGH);
  digitalWrite(relay6, HIGH);
  digitalWrite(relay7, HIGH);
  digitalWrite(relay8, HIGH);
  uint16_t ID = tft.readID();
  if (ID == 0xD3D3) ID = 0x9481; // write-only shield
  tft.begin(ID);
  tft.setRotation(0);           //PORTRAIT
  tft.fillScreen(BLACK);        //CLEAR SCREEN
  //----------------- BUTTON INFO  -----------------
  //                        POSITION INFO, border, background, writing colour, "text", size
  SIDEON_btn.initButton(&tft,   160, 45, 240, 60, RED, WHITE, RED,     "*SIDE ON*", 4);
  BRAKE_btn.initButton(&tft,  160, 110, 240, 60, RED, WHITE, RED,    "* BRAKE *", 4);
  LIND_btn.initButton(&tft,   160, 175, 240, 60, WHITE, ORANGE, RED,  "*  IND   ", 4);
  RIND_btn.initButton(&tft,   160, 240, 240, 60, WHITE, ORANGE, RED,  "   IND  *", 4);
  LSIDE_btn.initButton(&tft,  160, 305, 240, 60, WHITE, RED, WHITE,     "* SIDE  ", 4);
  RSIDE_btn.initButton(&tft,  160, 370, 240, 60, WHITE, RED, WHITE,     "  SIDE *", 4);
  FOG_btn.initButton(&tft,    160, 435, 240, 60, GREEN, RED, GREEN,     "  FOG  *", 4);
    SIDE_btn.initButton(&tft,   95, 45, 115, 60, RED, WHITE, RED,     "* SIDE *", 4);
    SIDE1_btn.initButton(&tft,  220, 45, 115, 60, RED, WHITE, RED,     "* SIDE *", 4);
  //SIDE_btn.drawButton(false);
  SIDEON_btn.drawButton(false);
  BRAKE_btn.drawButton(false);
  LIND_btn.drawButton(false);
  RIND_btn.drawButton(false);
  RSIDE_btn.drawButton(false);
  LSIDE_btn.drawButton(false);
  FOG_btn.drawButton(false);
  bool down = Touch_getXY();
  //  SIDE_btn.press(down && SIDE_btn.contains(pixel_x, pixel_y));
  SIDEON_btn.press(down && SIDE_btn.contains(pixel_x, pixel_y));
  BRAKE_btn.press(down && BRAKE_btn.contains(pixel_x, pixel_y));
  LIND_btn.press(down && LIND_btn.contains(pixel_x, pixel_y));
  RIND_btn.press(down && RIND_btn.contains(pixel_x, pixel_y));
  RSIDE_btn.press(down && RSIDE_btn.contains(pixel_x, pixel_y));
  LSIDE_btn.press(down && LSIDE_btn.contains(pixel_x, pixel_y));
  FOG_btn.press(down && FOG_btn.contains(pixel_x, pixel_y));
  //  if (SIDE_btn.justReleased())
  //    SIDE_btn.drawButton();
  if (SIDEON_btn.justReleased())
    SIDEON_btn.drawButton();
  if (BRAKE_btn.justReleased())
    BRAKE_btn.drawButton();
  if (LIND_btn.justReleased())
    LIND_btn.drawButton();
  if (RIND_btn.justReleased())
    RIND_btn.drawButton();
  if (RSIDE_btn.justReleased())
    RSIDE_btn.drawButton();
  if (LSIDE_btn.justReleased())
    LSIDE_btn.drawButton();
  if (FOG_btn.justReleased())
    FOG_btn.drawButton();
  if (SIDEON_btn.justPressed()) {
    SIDEON_btn.drawButton(true);
    if (SIDEON == true ) {
      digitalWrite(relay1, HIGH );
      SIDEON = false;                               //expected primary-expression before '==' token
    else {
      digitalWrite(relay1, LOW );
      SIDEON = true;
    if (BRAKE_btn.justPressed()) {
      BRAKE_btn.drawButton(true);
      digitalWrite(relay5, LOW);
      delay(ON);
    if (LSIDE_btn.justPressed()) {
      LSIDE_btn.drawButton(true);
      digitalWrite(relay1, LOW);
      delay(ON);
    if (RSIDE_btn.justPressed()) {
      RSIDE_btn.drawButton(true);
      digitalWrite(relay2, LOW);
      delay(ON);
    if (FOG_btn.justPressed()) {
      FOG_btn.drawButton(true);
      digitalWrite(relay6, LOW);
      delay(ON);
    if (LIND_btn.justPressed()) {
      LIND_btn.drawButton(true);
      for (int i = 0; i < NUM_FLASH; i++) {
        digitalWrite(relay3, LOW);
        delay(FLASH_ON);
        delay(FLASH_OFF);
    if (RIND_btn.justPressed()) {
      RIND_btn.drawButton(true);
        digitalWrite(relay4, LOW);
        delay(FLASH_ON);
        delay(FLASH_OFF);
