HELP: Transmit Data Over Laser and Recieve from LDR
As title say, I want to send data (i.e. text later .bmp file) from one Arduino to another by laser turn ON and OFF respectively HIGH and LOW and receive it from LDR.
I have to use Matlab as Sender and Python ( Visual Studio Code) as Receiver side.
So far, I have managed the task successfully when I use Matlab for both sides.
Video in Link : Short Video
In the video, there might be shown some other electronic components, but I deactivated all of them so I don't need them. The circuit is very simple:
Sender: Laser Module, S goes to Arduino Digital 3, GND to Arduino GND
Receiver: There is a resistor serial to LDR where LDR reader pin goes to Arduino Digital 3 Pin, GND-GND. That's all. Remaining components are irrelevant.
Sender Code:
a = arduino("COM5","Uno");
foku = fopen('test.txt','r');
if true
writeDigitalPin(a,'D3',1);
while ~feof(foku)
    byte_content = fread(foku, 1, 'uint8');
    if byte_content>-1
        b1 = bitget(byte_content, 1:8);
        for j=1:1:8
            fprintf("%d",b1(j));
            writeDigitalPin(a,'D3',b1(j));
             pause(1/100);
        end
    end
end
fclose(foku);
end
Reciever Code:
b = arduino("COM6","Uno");
fyaz = fopen("new123.txt","w");
if true
while readDigitalPin(b,'D3')~=1
    fprintf('waiting-');
end
for x=1:1:26
    dizi=(8);
    for j=1:1:8
        dizi(j)=readDigitalPin(b,'D3');
        fprintf('%d',dizi(j));
        pause(1/100);
    end
sayi=0;
for c=1:1:8
    sayi=sayi+(dizi(c)*power(2,c-1));
end
fwrite(fyaz,sayi,'uint8');
end
fclose(fyaz);
end
What I'm asking, I couldn't make it work when I use Python as receiver. It starts well for first 3-4 bytes and then I get wrong characters due to wrong bits pattern. As you all assume, at some point there is a synchronize problem sender and receiver.
Are they give same delay time, Matlab pause(1/100) function and Python time.sleep(1/100)?
Here is my draft code in Python:
import pyfirmata
import time
board = pyfirmata.Arduino('COM6')
f = open("demo.txt", "w")
f2 = open("demo2.txt", "w")
button = board.digital[3]
it = pyfirmata.util.Iterator(board)
it.start()
button.mode = pyfirmata.INPUT
time.sleep(3)
while button.read() != 1:
    print("waiting-")
for i in range(7):
    dizi = [0,0,0,0,0,0,0,0]
    for j in range(8):
     dizi[j] = board.digital[3].read()
     f2.write(str(int(dizi[j])))
     time.sleep(1/100)
    sayi=0
    for c in range(8):
            sayi = sayi+(dizi[c]*int(pow(2,c-1)))
    print(str(sayi))
    f.write(chr(sayi))
f.close()
f2.close()
I'm going to record and upload a video for this code soon. So, you all may get know well where I'm missing something. I would be happy if you teach me better way to handle this task.
Thank you all for your interests.
Hi. Do you have an oscilloscope to check if LDR is responsible enough?
And the temperature of LDR is good to checking while transmitting. under heat drift his resistance.
You don’t mention a bitrate in your code, but assuming you know what you’re doing, I’d strongly suggest you use a modulation scheme… e.g the. beam is driven at say 40khz+, and your data is used to gate that on/off. there are certainly more elaborate methods, but that would be a good starting point.
e.g. 3 cycles on == a 1 bit, 3 cycles off == a zero bit.
An LDR will be way too slow to react on 40 kHz. For something like this you need a fotodiode or a foto-transistor.
best regards Stefan
Good point… I was assuming a rethink from scratch with the appropriate technology!
