HELP: Transmitting DHT11 and LDR to wireless 433Mhz receiver and display values
Hi I new to this forum and would like some help with a program i am trying to write. I have a 433 Mhz transmitter and receiver which i'm trying to use to send Temperature and Humidity values from a DHT11 sensor and also values for Lux via analogue A0.
I have figured out how to make the transmitter send constant data for these values in the following form, , and . I studied another project to do it this way.
I have also had luck receiving this data and have tried to extend the project so that when one of these values is detected it displays Temp: XX, Humidity: XX etc on the serial port. I'm have problems get the code to except IF statements and print the values correctly.
I have played about so much i think i have messed up the code for the receiver
#include <VirtualWire.h>
byte message[VW_MAX_MESSAGE_LEN]; // a buffer to store the incoming messages
byte messageLength = VW_MAX_MESSAGE_LEN; // the size of the message
char inData[24];
byte index;
char reply[80];
boolean started = true;
boolean ended = true;
// Init VWMsgBuf.
uint8_t VWMsgBuf[VW_MAX_MESSAGE_LEN];
// Init VWMsgStr.
String VWMsgStr;
Serial.println("Device is ready");
// Initialize the IO and ISR
vw_setup(2000); // Bits per sec
vw_rx_start(); // Start the receiver
 uint8_t VWBufLen = VW_MAX_MESSAGE_LEN;
  if (vw_get_message(VWMsgBuf, &VWBufLen)) {
    // Flash a light to show received good message.
    digitalWrite(13, true);
    // Message with a good checksum received, dump it.
    VWMsgStr = "";
    for (int i = 0; i < VWBufLen; i++) {
//.write(message[i]);
  while(Serial.available() > 0)
   char aChar = Serial.read();
      if(aChar == '<')
         started = true;
         index = 0;
         reply[index] = '\0';
      else if(aChar == '>')
        ended = true;
      else if(started)
         reply[index] = aChar;
         index++;
         reply[index] = ' ';
      if(started && ended)
        if(inData[0] == 'T')
	  // inData[0] = ' ';
	 //  int windVal = atoi(inData);
           Serial.println(" ");
           Serial.print("GotReply");
	   Serial.print("Temp:");
           Serial.print(inData);
           Serial.print("C");
	started = false;
	ended = false;
	index = 0;
	inData[index] = ' ';
TX code used
#define DEBUG
// Init VWMsgBuf.
char VWMsgBuf[VW_MAX_MESSAGE_LEN];
// Init VWMsgStr. for humidy, temperature and Lux
String VWMsgStr; //for humidity
String VWMsgStrT; // for temperature
String VWMsgStrL; // for Lux
#include <wire.h>
#include <dht11.h>
// Init DHT11.
dht11 DHT11;
// DHT11 OUT to digital I/O pin.
#define DHT11_PIN 2
unsigned int Luxdata;
// setup() runs once after reset.
  #ifdef DEBUG
    // Init serial for debugging.
  #endif
  // Init BPS.
  vw_setup(2000);
  // Send setup() message.
  //VWMsgStr = "REMOTE1: setup()!";
  VWTX(VWMsgStr);
  VWTXT(VWMsgStrT);
  VWTXL(VWMsgStrL);
  Lux();
  //#endif
// loop() runs continuously after setup().
  VWTX(VWMsgStr);
  VWTXT(VWMsgStrT);
  VWTXL(VWMsgStrL);
  #ifdef DEBUG
    Serial.println(VWMsgStr);
    Serial.println(VWMsgStrT);
    Serial.println(VWMsgStrL);
  #endif
  // Send DHT11 message.
  int rc = DHT11.read(DHT11_PIN);
  switch (rc) {
    case DHTLIB_OK:
      VWMsgStr = "<H" + String(DHT11.humidity) + ">";
      VWMsgStrT = "<T" + String(DHT11.temperature) + ">";
      //VWMsgStr += "  TempF: " + String(fahrenheit(DHT11.temperature));
    case DHTLIB_ERROR_CHECKSUM:
      VWMsgStr = "REMOTE1: Checksum!";
    case DHTLIB_ERROR_TIMEOUT:
      VWMsgStr = "REMOTE1: Time Out!";
    default:
      VWMsgStr = "REMOTE1: Unknown!";
    VWMsgStrL = "<L" + String(Luxdata) + ">";
// Virtual Wire Transmit msgStr
void VWTX(String VWMsgStr) {
  VWMsgStr.toCharArray(VWMsgBuf, VW_MAX_MESSAGE_LEN);
  uint8_t VWMsgBufLen = strlen(VWMsgBuf);
  digitalWrite(13, true); // Flash a light to show transmitting
  vw_send((uint8_t *)VWMsgBuf, strlen(VWMsgBuf));
  vw_wait_tx(); // Wait until the whole message is gone
  digitalWrite(13, false);
// Virtual Wire Transmit msgStr for temperature
void VWTXT(String VWMsgStrT) {
  VWMsgStrT.toCharArray(VWMsgBuf, VW_MAX_MESSAGE_LEN);
}// Virtual Wire Transmit msgStr for temperature
void VWTXL(String VWMsgStrL) {
  VWMsgStrL.toCharArray(VWMsgBuf, VW_MAX_MESSAGE_LEN);
/* Main program */
void Lux(){
  /* Temporarily holds the value read from analogue input A0 */
  /* Read the analogue input A0... */
  Luxdata = analogRead(A0);
Im really stuck and would really appreciate some help
Cheers
