HELP: tri axis Accelerometer smoothing
hello, is there anyone who have code for smoothing the output of the accelerometer..? for 2 servo txn :slight_smile:
That's often just averaging a "few" reads -- 2,3,4 reads, average o/p -- whatever.
Try: File / Examples / Analog / Smoothing
Try in loop:
new_value = A * get_new_value() + B * old_value;
old_value = new_value
where A + B = 1.0
for example A=0.1 and B=0.9, the smaller the A the stronger the low-pass filtering effect.
p.
WillR:
sir can you have example..? i got some code in the google but it's not working my newbie :slight_smile: tnx
It has already been pointed out that the Arduino compiler comes with examples that shows how to do this.
I have over fourty years in designing and building computer systems. The first thing I did with my new Arduino is to compile test and run every example that I could get to work.
If I am not too proud to use the examples to learn -- maybe you could try it too. When I had trouble with specific items people were happy to help.
I will not write your code. Nor it seems will the other experienced people. It's just too much...
If you want a course for beginners -- use google -- maybe there are some tutorials.
i tried it sir
Good.
How was it?
i'ts working but a little bit un smooth.. sir what about Kalman method.>? it is good to used..?
