Help triggering sound
Hello! Completely new to Arduino; working on building a cornhole-type game that keeps score and triggers a sound when the bean bag passes through the hole.
I've got IR Break Beam sensors set up and have managed to code the scoring system.
Having trouble triggering a file to play from an SD card though. I know that the set-up and speaker are working, as I've been able to get a sound to play using some simple sample code from the web. But when I try to integrate that into my existing code, I come up short.
Appreciate any insights from this group - I'm sure it answer will jump out at someone here!
Thanks in advance.
#include <SPI.h>
#include <SD.h>
#include "TMRpcm.h" // includes the library for music playback
#include <LiquidCrystal.h> // includes the library code for LCD
#define SENSORPIN1 6 // sets SENSORPIN1 as pin 6
#define SENSORPIN2 5 // sets SENSORPIN2 as pin 5
#define SENSORPIN3 8 // sets SENSORPIN3 as pin 8
#define SD_ChipSelectPin 10 // sets the SD card as pin 10
TMRpcm music; //Lib object is named "music"
LiquidCrystal lcd(0, 1, 2, 3, 4, 7); // initialize the library with the numbers of the interface pins
int sensorState1 = 0; // variable for reading IR sensor 1
int sensorState2 = 0; // variable for reading IR sensor 2
int HomeScore; // variable for Home Score
int AwayScore; // variable for Away Score
pinMode(SENSORPIN1, INPUT); // initiate SENSORPIN1 as an input
digitalWrite(SENSORPIN1, HIGH); // turn the pullup for SENSORPIN1 on
pinMode(SENSORPIN2, INPUT); // initiate SENSORPIN2 as an input
digitalWrite(SENSORPIN2, HIGH); // turn the pullup for SENSORPIN2 on
lcd.begin(16, 2); // set up the LCDs number of columns and rows:
setupScreen(); // Print a message to the LCD.
music.speakerPin = 9; // set speaker output as pin 9
void setupScreen() // what appears on the LCD screen at start
lcd.clear(); // clear LCD screen
lcd.setCursor(0,0); // set cursor position for LCD screen
lcd.print("FRANCE v GERMANY"); // what to display at start
HomeScore = 0; // value for HomeScore variable
AwayScore = 0; // value for AwayScore variable
void loop(){
sensorState1 = digitalRead(SENSORPIN1); // tells arduino to get the value of sensorState1 by reading SENSORPIN1
if (sensorState1 == LOW) { // if the value is LOW (broken) then...
HomeScore++; // advance Home Score by 1 pt
delay(500); // delay to prevent multiple scoring
music.play("test.wav"); // play file from SD card
sensorState2 = digitalRead(SENSORPIN2); // tells arduino to get the value of sensorState2 by reading SENSORPIN2
if (sensorState2 == LOW) {
HomeScore++;
lcd.setCursor(2, 1); // set the cursor position for the Home Score
lcd.print(HomeScore); // print the HomeScore variable
lcd.setCursor(12, 1); // set the cursor position for the Away Score
lcd.print(AwayScore); // print the AwayScore
What does that mean?
Please remember to use code tags when posting code
Come up short means I can't figure it out.
Sorry to not follow convention...what do you mean by using "code tags"? Happy to oblige once I know what it means :slight_smile: :grinning:
What is "it"? What actually happens that shouldn't, or doesn't happen that should? We're asking for a detailed description of the problem...
For an explanation of code tags, read the introductory threads at the top of the forum.
This is a very old, obsolete and non-portable version of:
pinMode(SENSORPIN1, INPUT_PULLUP); // initiate SENSORPIN1 as an input
Is the score incrementing?
Oh, didn't realize. Can you suggest an alternative?
When the IR sensor is broken, I want it to advance the score by 1 pt (and display on the LCD) as well play the sound "test.wav" from the SD card.
With the code I have, I can get the scoring to work and posted to the LCD. But the sound does not play.
I though the command "music.play" would trigger the sound but it does not.
I think I might be missing something in the setup?
Please add the code tags so people will be motivated to look.
Sorry, I don't know what is meant by "code tags". Can you give me an example?
Why can you not just go read the instructions? It's all in the threads I mentioned. It's like this:
#include <SPI.h>
#include <SD.h>
  lcd.setCursor(0, 0); // set cursor position for LCD screen
    HomeScore++;
Notice how much easier it is to read, with auto formatting.
I think the visiting team might be angry that all their points go to the home team. :slight_smile:
Can you post the sketch that did play sound?
Just found it but you beat me to it! Thanks.
Yes, while I'm drafting it up the Home Team gets all the points :smiley:
I noticed that in setup() you failed to do an SD.begin().
#include "SD.h"
#define SD_ChipSelectPin 4
#include "TMRpcm.h"
#include "SPI.h"
TMRpcm tmrpcm;
void setup(){
tmrpcm.speakerPin = 9;
if (!SD.begin(SD_ChipSelectPin)) {
Serial.println("SD fail");
return;
tmrpcm.setVolume(5);
tmrpcm.play("test.wav");
void loop(){  }
No, I didn't! This initializes the SD card?
What does the SD library documentation say?
@ToddL1962 That did it!!! Thank you so much. Really appreciate your insight.
