I have a project with arduino uno to read 5 DS18B20 sensors and send it as string to the exosite. all done with standart onewire and exosite libraries - works perfectly. Then I needed to expand my system with 4 aditional sensors. When done, I ran in to SRAM memory shortage and the whole system hanging.. My idea was to "optimize" the code by changing temerature variables from float to integer so I modified the code as folowing:
#include <EEPROM.h>
#include <SPI.h>
#include <Ethernet.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Exosite.h>
// Pin use
#define ONEWIRE 7 //pin to use for One Wire interface
// Set up which Arduino pin will be used for the 1-wire interface to the sensor
OneWire oneWire(ONEWIRE);
DallasTemperature sensors(&oneWire);
String cikData = "XXXXXXXXXXXXXXXXXXXXXX"; // <-- FILL IN YOUR CIK HERE! (https://portals.exosite.com -> Add Device)
byte macData[] = {0x22, 0x7A, 0xFE, 0xFC, 0xFE, 0xF2}; // <-- FILL IN YOUR Ethernet shield's MAC address here.
// User defined variables for Exosite reporting period and averaging samples
#define REPORT_TIMEOUT 30000 //milliseconds period for reporting to Exosite.com
#define SENSOR_READ_TIMEOUT 25000 //milliseconds period for reading sensors in loop
class EthernetClient client;
Exosite exosite(cikData, &client);
Serial.println("Boot");
// Start up the OneWire Sensors library
sensors.begin();
Serial.println("Starting Exosite Temp Monitor");
Serial.print("OneWire Digital Pin Specified: ");
Serial.println(ONEWIRE);
Ethernet.begin(macData);
// wait 3 seconds for connection
delay(3000);
static unsigned long sendPrevTime = 0;
static unsigned long sensorPrevTime = 0;
int tC;
static float tC2;
int tC3;
int tC4;
int tC5;
int tC6;
int tC7;
int tC8;
int tC9;
char buffer[7];
String readParam = "";
String writeParam = "";
String returnString = "";
Serial.print("."); // print to show running
// Read sensor every defined timeout period
if (millis() - sensorPrevTime > SENSOR_READ_TIMEOUT) {
Serial.println("Requesting temperature...");
sensors.requestTemperatures(); // Send the command to get temperatures
tC = sensors.getTempCByIndex(0);
Serial.print("Celsius: ");
Serial.print(tC);
Serial.println(" C ..........DONE");
tC2 = sensors.getTempCByIndex(1);
Serial.print("Celsius2: ");
Serial.print(tC2);
tC3 = sensors.getTempCByIndex(2);
Serial.print("Celsius3: ");
Serial.print(tC3);
tC4 = sensors.getTempCByIndex(3);
Serial.print("Celsius4: ");
Serial.print(tC4);
tC5 = sensors.getTempCByIndex(4);
Serial.print("Celsius5: ");
Serial.print(tC5);
tC6 = sensors.getTempCByIndex(5);
Serial.print("Celsius6: ");
Serial.print(tC6);
tC7 = sensors.getTempCByIndex(6);
Serial.print("Celsius7: ");
Serial.print(tC7);
tC8 = sensors.getTempCByIndex(7);
Serial.print("Celsius8: ");
Serial.print(tC8);
tC9 = sensors.getTempCByIndex(8);
Serial.print("Celsius9: ");
Serial.print(tC9);
sensorPrevTime = millis();
// Send to Exosite every defined timeout period
if (millis() - sendPrevTime > REPORT_TIMEOUT) {
Serial.println(); //start fresh debug line
Serial.println("Sending data to Exosite...");
readParam = ""; //nothing to read back at this time e.g. 'control&status' if you wanted to read those data sources
writeParam = "t="; //parameters to write e.g. 'temp=65.54' or 'temp=65.54&status=on'
//String tempValue = dtostrf(tC, 1, 2, buffer); // convert float to String, minimum size = 1, decimal places = 2
writeParam += tC; //add converted temperature String value
//writeParam += "&message=hello"; //add another piece of data to send
writeParam +="&t2=";
//tempValue = dtostrf(tC2, 1, 2, buffer);
String tempValue = dtostrf(tC2, 1, 2, buffer);
writeParam += tempValue;
writeParam +="&t3=";
writeParam += tC3;
writeParam +="&t4=";
writeParam += tC4;
writeParam +="&t5=";
writeParam += tC5;
writeParam +="&t6=";
writeParam += tC6;
writeParam +="&t7=";
writeParam += tC7;
writeParam +="&t8=";
writeParam += tC8;
writeParam +="&t9=";
writeParam += tC9;
Serial.println("Exosite String");
Serial.println(writeParam);
if ( exosite.writeRead(writeParam, readParam, returnString)) {
Serial.println("Exosite OK");
if (returnString != "") {
Serial.println("Response:");
Serial.println(returnString);
else {
Serial.println("Exosite Error");
sendPrevTime = millis(); //reset report period timer
Serial.println("done sending.");
delay(1000); //slow down loop
and then I got this (picture attached)
I cant figure out why all the temperature sensors as integers show the right temperature, but when they are added to the string they change.. what am I missing?
