Help troubleshoot ESP-12E AT command communications with the A7670SA
I'm able to connect the A7670SA module to the computer directly and run AT commands via UART and accomplish what I need.
When I connect the A7670SA module to the RX/TX of the NodeMCU, I'm able to communicate and send and receive responses.
My sketch utilizes the AT+HTTP commands to get the geo location and store it in a firebase database. When I manually use these commands via UART I'm able to transmit the data to the database.
However when I connect it to the NodeMCU, I am unable as I receive errors and weird characters in the response.
Here is my code:
#include <SoftwareSerial.h>
#define A7670_RX D2 // Connect A7670 TX pin to NodeMCU D2 pin
#define A7670_TX D3 // Connect A7670 RX pin to NodeMCU D3 pin
#define LED_PIN D4   // Define the pin connected to the built-in blue LED
SoftwareSerial A7670Serial(A7670_RX, A7670_TX); // RX, TX
  pinMode(LED_PIN, OUTPUT); // Set the LED pin as an output
  digitalWrite(LED_PIN, HIGH); // Turn on the LED initially
  Serial.begin(115200); // Initialize serial communication with Arduino IDE Serial Monitor
  A7670Serial.begin(115200); // Initialize SoftwareSerial communication with A7670 module
  A7670Serial.write(static_cast<char>(0x00)); // Send a null character to clear any pending data
  if (Serial.available()) {
    String command = Serial.readStringUntil('\n');
    sendATCommand(command);
void sendATCommand(String command) {
  Serial.print("Sending command: ");
  Serial.println(command);
  digitalWrite(LED_PIN, LOW); // Turn off the LED
  A7670Serial.println(command);
  delay(1000); // Delay to ensure command is sent
  // Wait for response
  delay(1000); // Add delay according to the expected response time
  while (A7670Serial.available()) {
    String response = A7670Serial.readStringUntil('\n');
    Serial.println("Response from A7670: " + response);
Here is sample output:
For example, when I send AT
Response from A7670: AT OK
when I send AT+HTTPINIT
Response from A7670: AT+HTTPINIT OK
But when I send AT+HTTPPARA="URL","https://databaseexample-83d98-default-rtdb.firebaseio.com/.json?auth=ABcDeF09fvOPQRsFy3WXJTl6x1VdPUO34OkFJSIE0y"
I receive back:
Response from A7670: AT+HTTPPARA="URL","httpš"��j"���ձѵ�ё��2RRdPUO34OkFJSIE0y"
Response from A7670: ERROR
I have tried many things, including chunking out the buffer, but nothing seems to work.
Please help.
did you use espsoftwareserial
yes. using v. 8.1.0.
I started figuring it out. I think it has to do with the length of the URL. I'm trying chunking it. Sometimes it works, sometimes it doesn't
I got it to work, by chunking out requests that were too long. Here is the code for anyone who also encounters this problem:
String response = "";
int retrycount = 0;
String dbURL = ("https://database-12a22-default-rtdb.firebaseio.com/.json?auth=POR09fvOhxdrFy23456kle2dFGO34OrolerTSD");
String jsondata = "{\"f_latitude\":\"43.3385544\",\"f_longitude\":\"70.1003989\",\"f_lastupdated\":\"2%507027%50702024+12%516550PM+ET\"}";
int jsonlen = jsondata.length();
  A7670Serial.begin(115200, SWSERIAL_8N1); // Initialize SoftwareSerial communication with A7670 module, 8 data bits, no parity, 1 stop bit
    if (command == "send") {
      if (sendATCommand("AT", "Check Module")) {
        sendATCommand("AT+HTTPINIT", "HTTPINIT");
        delay(5000);
        sendATCommand("AT+HTTPPARA=\"URL\",\"" + dbURL + "\"", "HTTPPARA URL");
        delay(5000);
        sendATCommand("AT+HTTPPARA=\"CONTENT\",\"application/json\"", "HTTPPARA JSON");
        delay(5000);
        sendATCommand("AT+HTTPDATA=" + String(jsonlen) + ",10000", "HTTPDATA COUNT");
        delay(5000);
        sendATCommand(jsondata, "DATA");
        delay(5000);
        sendATCommand("AT+HTTPACTION=4", "POST ACTION");
        delay(5000);
        sendATCommand("AT+HTTPHEAD", "HEAD RESPONSE");
        delay(5000);
        sendATCommand("AT+HTTPTERM", "HTTP TERMINATE");
        Serial.println("Module not ready.");
      sendATCommand(command, command);
  if (A7670Serial.available()) {
bool sendATCommand(String command, String commandName) {
  Serial.println(commandName);
  // Clear serial buffer
  while (A7670Serial.available() > 0) {
    A7670Serial.read();
  // Send command in chunks
  int len = command.length();
  int index = 0;
  while (index < len) {
    int chunkSize = min(32, len - index); // Limit chunk size to 32 characters
    A7670Serial.print(command.substring(index, index + chunkSize));
    index += chunkSize;
    delay(100); // Add a small delay between sending chunks
  A7670Serial.println(); // Send newline at the end
  unsigned long startTime = millis();
  String response;
  do {
      Serial.println(response);
      if (response.startsWith("OK") || response.startsWith("DOWNLOAD")) {
        Serial.println(); // Print a newline after the response
        retrycount = 0;
        return true; // Exit the loop and function
      if (response.startsWith("ERROR") && commandName != "HEAD RESPONSE") {
        if (retrycount < 3) {
          retrycount++;
          Serial.println("\nError response from A7670 ... retry #" + String(retrycount));
          delay(3000); // Wait for 3 seconds
          // Retry sending the command again
          sendATCommand(command, commandName);
    // If no response yet, print dots
    Serial.print(".");
    delay(500); // Wait for half a second
  } while (millis() - startTime < 10000); // Timeout after 10 seconds
  // If timeout reached
  Serial.println("\nTimeout waiting for response from A7670.");
  retrycount = 0;
  return false;
