HELP! Trying to exit a for loop FADE with momentary PushButton
I'm very new at programming and Arduino.
I'm basically using a momentary pushbutton to turn on an RGB Led, and at each press it changes the color; Solid states first, then a fading state by button press 8.
Now when using a for loop in my switch statements for PWM fading, it is impossible to exit the for loop with a button press!
I'm following along in a book, exploring arduino, but it doesnt explain this.
HOW DO I EXIT THE FOR LOOP WITH THE PUSH BUTTON??? Ive tried so many things
Here is my code:
const int BLED = 8;
const int GLED = 9;
const int RLED = 10;
const int BUTTON = 2;
bool lastButton = LOW;
bool currentButton = LOW;
int ledMode = 0;          //Cycle betweeen LED states
  pinMode(BLED, OUTPUT);
  pinMode(GLED, OUTPUT);
  pinMode(RLED, OUTPUT);
  pinMode(BUTTON, INPUT);
bool debounce(bool last)
  bool current = digitalRead(BUTTON);
  if(last != current)
    delay(5);
  return current;
 * LED MODE SELECTION
 * Pass a number for the LED state and set it accordingly
void setMode(int mode)
  //RED
  switch(mode)
    case 1:
      digitalWrite(RLED, HIGH);
      digitalWrite(GLED, LOW);
      digitalWrite(BLED, LOW);
    case 2:
      digitalWrite(RLED, LOW);
      digitalWrite(GLED, HIGH);
    case 3:
      digitalWrite(BLED, HIGH);
    case 4:
      analogWrite(RLED, 255);
      analogWrite(GLED, 0);
      analogWrite(BLED, 255);
    case 5:
      analogWrite(RLED, 0);
      analogWrite(GLED, 255);
    case 6:
      analogWrite(BLED, 0);
    case 7:
      analogWrite(RLED, 220);
      analogWrite(GLED, 220);
      analogWrite(BLED, 220);
    case 8:
      //RED FADE
      for (int i = 0; i < 256; i++)
        analogWrite(RLED, i);
        delay(10);
      for(int i = 255; i > 0; i--)
        delay(10);
      default:
  currentButton = debounce(lastButton);
  if(lastButton == LOW && currentButton == HIGH)
    ledMode++;
  lastButton = currentButton;
   * If you've cycled through the different options,
   * reset the counter to 0
   if(ledMode == 9) ledMode = 0;
   setMode(ledMode);
Please check out this post:
It will help you understand how to post code.
Then, please edit your post to put your code in code tags.
You should also read this tutorial: several things at the same time
It will show you have to disassemble your for() loop. You should let the loop() function do the looping. Each time through loop(), with mode ==8, you write a new RGB value.
If you want to get rid of those delay()s as well, check out the Blink Without Delay example in the IDE (File->examples->02.digital->Blink Without Delay) to learn how to track elapsed time.
The program should be modified not to use a delay in the for loop. Instead, the function millis() should be used to determine the amount of time that has elapsed.
You can try the simulation
Below is the code:
const int BLED = 8;
const int GLED = 9;
  if(last != current)
    delay(5);
  return current;
  //RED
  switch(mode)
    case 1:
    case 2:
    case 3:
    case 4:
    case 5:
    case 6:
    case 7:
    case 8:
      //RED FADE
      /*GERRY MOD
        delay(10);
        delay(10);
      static int redCounter = 0;
      static bool redGoingUp = true;
      static unsigned long prevRedTime = millis();
      if (millis() - prevRedTime > 20) {
        if (redGoingUp) {
          if (redCounter == 255) {
            redGoingUp = false;
            redCounter++;
          if (redCounter == 0) {
            redGoingUp = true;
            redCounter--;
      analogWrite(RLED, redCounter);
      default:
    ledMode++;
   setMode(ledMode);
That's awesome! I'm researching a bunch about using Millis now instead of delay do that other code can be executed.
Highly appreciate the step in the right direction.
It's not quite fading exactly how I'm wanting but it's a great help.
Thanks Gerivega!
