HELP! Trying to exit a for loop FADE with momentary PushButton
The program should be modified not to use a delay in the for loop. Instead, the function millis() should be used to determine the amount of time that has elapsed.
You can try the simulation
Below is the code:
const int BLED = 8;
const int GLED = 9;
const int RLED = 10;
const int BUTTON = 2;
bool lastButton = LOW;
bool currentButton = LOW;
int ledMode = 0;          //Cycle betweeen LED states
  pinMode(BLED, OUTPUT);
  pinMode(GLED, OUTPUT);
  pinMode(RLED, OUTPUT);
  pinMode(BUTTON, INPUT);
bool debounce(bool last)
  bool current = digitalRead(BUTTON);
  if(last != current)
    delay(5);
  return current;
 * LED MODE SELECTION
 * Pass a number for the LED state and set it accordingly
void setMode(int mode)
  //RED
  switch(mode)
    case 1:
      digitalWrite(RLED, HIGH);
      digitalWrite(GLED, LOW);
      digitalWrite(BLED, LOW);
      break;
    case 2:
      digitalWrite(RLED, LOW);
      digitalWrite(GLED, HIGH);
      break;
    case 3:
      digitalWrite(BLED, HIGH);
      break;
    case 4:
      analogWrite(RLED, 255);
      analogWrite(GLED, 0);
      analogWrite(BLED, 255);
      break;
    case 5:
      analogWrite(RLED, 0);
      analogWrite(GLED, 255);
      break;
    case 6:
      analogWrite(BLED, 0);
      break;
    case 7:
      analogWrite(RLED, 220);
      analogWrite(GLED, 220);
      analogWrite(BLED, 220);
      break;
    case 8:
      //RED FADE
      /*GERRY MOD
      for (int i = 0; i < 256; i++)
        analogWrite(RLED, i);
        delay(10);
      for(int i = 255; i > 0; i--)
        delay(10);
      static int redCounter = 0;
      static bool redGoingUp = true;
      static unsigned long prevRedTime = millis();
      if (millis() - prevRedTime > 20) {
        if (redGoingUp) {
          if (redCounter == 255) {
            redGoingUp = false;
            redCounter++;
          if (redCounter == 0) {
            redGoingUp = true;
            redCounter--;
      analogWrite(RLED, redCounter);
      break;
      default:
  currentButton = debounce(lastButton);
  if(lastButton == LOW && currentButton == HIGH)
    ledMode++;
  lastButton = currentButton;
   * If you've cycled through the different options,
   * reset the counter to 0
   if(ledMode == 9) ledMode = 0;
   setMode(ledMode);
