It is reading the data, I am able to connect to it trough VB.NET. But nothing happens.
Thanks in advance.
// Declarations
#include <SPI.h>
#include <Ethernet.h>
// Wired configuration parameters
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0xD1, 0x4B };
unsigned char local_ip[] = {192,168,1,5}; // IP address of WiShield
unsigned char gateway_ip[] = {192,168,1,1}; // router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0}; // subnet mask for the local network
int E1 = 8;
int M1 = 9;
int E2 = 6;
int M2 = 7;
const int trigPin = 12;
const int echoPin = 13;
EthernetServer server(80);
//char buffer[20];
String buffer = "";
pinMode(M1,OUTPUT);
pinMode(M2,OUTPUT);
Ethernet.begin(mac, local_ip);
long afstan;
afstan = afstand();
if (client)
boolean currentLineIsBlank = true;
while (client.connected())
if (client.available())
char c = client.read();
if (afstan < 10)
Serial.print(c);
analogWrite(E1, 0); //PWM Speed Control
analogWrite(E2, 0); //PWM Speed Control
else {
switch (c) {
case 'v':
digitalWrite(M1,HIGH);
digitalWrite(M2, HIGH);
analogWrite(E1, 255); //PWM Speed Control
analogWrite(E2, 255); //PWM Speed Control
case 'a':
digitalWrite(M1,LOW);
digitalWrite(M2, LOW);
case 'r':
case 'l':
case 's':
long afstand(){
long duration,cm;
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
cm = microsecondsToCentimeters(duration);
Serial.print(cm);
Serial.print("cm");
return cm;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
