To expand on this, I would connect the WP pin to an output pin on the MCU with an external pull-up. The output pin is obviously to allow the program to switch between write protected and not write protected. The external pull-up is to ensure that the write protection is on while the pin is floating (power on, reset, brownout, etc.)
Edit: Noise does happen, also on I2C busses. In most cases they're not permanent though, but it would be here. I'm not gonna argue this further, do what you wish, it just seems like such a tiny thing for some additional reassurance.
The PCB I'm designing is simply for local data acquisition storage, (EEPROM + SD), RTC and Display. The I2C lines are very so short I don't expect I2C noise to be much of an issue. In any case if I loose a data point or two it will have minimal effect on the overall data usefulness.
