I'm working on integrating Arduino with a microscopy system. There is a pre-provided code, and I have understood parts of it, but most of it is still slightly above my level, and I was looking for some help as to understand what part of the code does what, exactly.
The code itself can be found here: https://valelab4.ucsf.edu/svn/micromanager2/trunk/DeviceAdapters/Arduino/AOTFcontroller/AOTFcontroller.ino
THe basics of my project is that I'm integrating Arduino, along with a PCB shield, into a laser-based microscopy system to improve communications between the lasers, the cameras, and the computer. Arduino is being interfaced with through this software called MicroManager. The main thing I know about the code is that it allows MicroManager to interact and communicate with the board
My Firefox doesn't like your link. You should post the code here.
That website's certificate has expired... post the code here.
The security certificate is only 14 days out of date so it is probably just an oversight. Here is the page:
This goal of the application is to set the digital output on pins 8-13
This can be accomplished in three ways. First, a serial command can directly set
the digital output pattern. Second, a series of patterns can be stored in the
Arduino and TTLs coming in on pin 2 will then trigger to the consecutive pattern (trigger mode).
Third, intervals between consecutive patterns can be specified and paterns will be
generated at these specified time points (timed trigger mode).
Interface specifications:
digital pattern specification: single byte, bit 0 corresponds to pin 8,
bit 1 to pin 9, etc.. Bits 7 and 8 will not be used (and should stay 0).
Set digital output command: 1p
Where p is the desired digital pattern. Controller will return 1 to
indicate succesfull execution.
Get digital output command: 2
Controller will return 2p. Where p is the current digital output pattern
Set Analogue output command: 3xvv
Where x is the output channel (either 1 or 2), and vv is the output in a
12-bit significant number.
Controller will return 3xvv:
Get Analogue output: 4
Set digital patten for triggered mode: 5xd
Where x is the number of the pattern (currently, 12 patterns can be stored).
and d is the digital pattern to be stored at that position. Note that x should
be the real number (i.e., not ASCI encoded)
Controller will return 5xd
Set the Number of digital patterns to be used: 6x
Where x indicates how many digital patterns will be used (currently, up to 12
patterns maximum). In triggered mode, after reaching this many triggers,
the controller will re-start the sequence with the first pattern.
Controller will return 6x
Skip trigger: 7x
Where x indicates how many digital change events on the trigger input pin
will be ignored.
Controller will respond with 7x
Start trigger mode: 8
Controller will return 8 to indicate start of triggered mode
Stop triggered a 9. Trigger mode will supersede (but not stop)
blanking mode (if it was active)
Stop Trigger mode: 9
Controller will return 9x where x is the number of triggers received during the last
trigger mode run
Set time interval for timed trigger mode: 10xtt
Where x is the number of the interval (currently, 12 intervals can be stored)
and tt is the interval (in ms) in Arduino unsigned int format.
Controller will return 10x
Sets how often the timed pattern will be repeated: 11x
This value will be used in timed-trigger mode and sets how often the output
pattern will be repeated.
Controller will return 11x
Starts timed trigger mode: 12
In timed trigger mode, digital patterns as set with function 5 will appear on the
output pins with intervals (in ms) as set with function 10. After the number of
patterns set with function 6, the pattern will be repeated for the number of times
set with function 11. Any input character (which will be processed) will stop
the pattern generation.
Controller will retun 12.
Start blanking Mode: 20
In blanking mode, zeroes will be written on the output pins when the trigger pin
is low, when the trigger pin is high, the pattern set with command #1 will be
applied to the output pins.
Controller will return 20
Stop blanking Mode: 21
Stops blanking mode. Controller returns 21
Blanking mode trigger direction: 22x
Sets whether to blank on trigger high or trigger low. x=0: blank on trigger high,
x=1: blank on trigger low. x=0 is the default
Controller returns 22
Get Identification: 30
Returns (asci!) MM-Ard\r\n
Get Version: 31
Returns: version number (as ASCI string) \r\n
Read digital state of analogue input pins 0-5: 40
Returns raw value of PINC (two high bits are not used)
Read analogue state of pint pins 0-5: 41x
x=0-5. Returns analogue value as a 10-bit number (0-1023)
Possible extensions:
Set and Get Mode (low, change, rising, falling) for trigger mode
Get digital patterm
Get Number of digital patterns
unsigned int version_ = 2;
// pin on which to receive the trigger (2 and 3 can be used with interrupts, although this code does not use interrupts)
int inPin_ = 2;
// to read out the state of inPin_ faster, use
int inPinBit_ = 1 << inPin_; // bit mask
// pin connected to DIN of TLV5618
int dataPin = 3;
// pin connected to SCLK of TLV5618
int clockPin = 4;
// pin connected to CS of TLV5618
int latchPin = 5;
const int SEQUENCELENGTH = 12; // this should be good enough for everybody;)
byte triggerPattern_[SEQUENCELENGTH] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
unsigned int triggerDelay_[SEQUENCELENGTH] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
int patternLength_ = 0;
byte repeatPattern_ = 0;
volatile long triggerNr_; // total # of triggers in this run (0-based)
volatile long sequenceNr_; // # of trigger in sequence (0-based)
int skipTriggers_ = 0; // # of triggers to skip before starting to generate patterns
byte currentPattern_ = 0;
const unsigned long timeOut_ = 1000;
bool blanking_ = false;
bool blankOnHigh_ = false;
bool triggerMode_ = false;
boolean triggerState_ = false;
// Higher speeds do not appear to be reliable
Serial.begin(57600);
pinMode(inPin_, INPUT);
pinMode (dataPin, OUTPUT);
pinMode (clockPin, OUTPUT);
pinMode (latchPin, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
// Set analogue pins as input:
DDRC = DDRC & B11000000;
// Turn on build-in pull-up resistors
PORTC = PORTC | B00111111;
digitalWrite(latchPin, HIGH);
if (Serial.available() > 0)
int inByte = Serial.read();
switch (inByte)
// Set digital output
case 1 :
if (waitForSerial(timeOut_))
currentPattern_ = Serial.read();
// Do not set bits 6 and 7 (not sure if this is needed..)
currentPattern_ = currentPattern_ & B00111111;
if (!blanking_)
PORTB = currentPattern_;
Serial.write( byte(1));
// Get digital output
case 2:
Serial.write( byte(2));
Serial.write( PORTB);
// Set Analogue output (TODO: save for 'Get Analogue output')
case 3:
int channel = Serial.read();
byte msb = Serial.read();
msb &= B00001111;
byte lsb = Serial.read();
analogueOut(channel, msb, lsb);
Serial.write( byte(3));
Serial.write( channel);
Serial.write(msb);
Serial.write(lsb);
// Sets the specified digital pattern
case 5:
int patternNumber = Serial.read();
if ( (patternNumber >= 0) && (patternNumber < SEQUENCELENGTH) )
triggerPattern_[patternNumber] = Serial.read();
triggerPattern_[patternNumber] = triggerPattern_[patternNumber] & B00111111;
Serial.write( byte(5));
Serial.write( patternNumber);
Serial.write( triggerPattern_[patternNumber]);
Serial.write( "n:");//Serial.print("n:");
// Sets the number of digital patterns that will be used
case 6:
int pL = Serial.read();
if ( (pL >= 0) && (pL <= 12) )
patternLength_ = pL;
Serial.write( byte(6));
Serial.write( patternLength_);
// Skip triggers
case 7:
skipTriggers_ = Serial.read();
Serial.write( byte(7));
Serial.write( skipTriggers_);
// starts trigger mode
case 8:
if (patternLength_ > 0)
sequenceNr_ = 0;
triggerNr_ = -skipTriggers_;
triggerState_ = digitalRead(inPin_) == HIGH;
PORTB = B00000000;
Serial.write( byte(8));
triggerMode_ = true;
// return result from last triggermode
case 9:
PORTB = B00000000;
Serial.write( byte(9));
Serial.write( triggerNr_);
// Sets time interval for timed trigger mode
// Tricky part is that we are getting an unsigned int as two bytes
case 10:
unsigned int highByte = 0;
unsigned int lowByte = 0;
highByte = Serial.read();
lowByte = Serial.read();
highByte = highByte << 8;
triggerDelay_[patternNumber] = highByte | lowByte;
Serial.write( byte(10));
Serial.write(patternNumber);
// Sets the number of times the patterns is repeated in timed trigger mode
case 11:
repeatPattern_ = Serial.read();
Serial.write( byte(11));
Serial.write( repeatPattern_);
// starts timed trigger mode
case 12:
PORTB = B00000000;
Serial.write( byte(12));
for (byte i = 0; i < repeatPattern_ && (Serial.available() == 0); i++)
for (int j = 0; j < patternLength_ && (Serial.available() == 0); j++)
PORTB = triggerPattern_[j];
delay(triggerDelay_[j]);
PORTB = B00000000;
// Blanks output based on TTL input
case 20:
blanking_ = true;
Serial.write( byte(20));
// Stops blanking mode
case 21:
blanking_ = false;
Serial.write( byte(21));
// Sets 'polarity' of input TTL for blanking mode
case 22:
int mode = Serial.read();
if (mode == 0)
blankOnHigh_ = true;
Serial.write( byte(22));
// Gives identification of the device
case 30:
Serial.println("MM-Ard");
// Returns version string
case 31:
Serial.println(version_);
case 40:
Serial.write( byte(40));
Serial.write( PINC);
case 41:
int pin = Serial.read();
if (pin >= 0 && pin <= 5)
int val = analogRead(pin);
Serial.write( byte(41));
Serial.write( pin);
Serial.write( highByte(val));
Serial.write( lowByte(val));
case 42:
int state = Serial.read();
Serial.write( byte(42));
Serial.write( pin);
if (state == 0)
digitalWrite(14 + pin, LOW);
Serial.write( byte(0));
if (state == 1)
digitalWrite(14 + pin, HIGH);
// In trigger mode, we will blank even if blanking is not on..
if (triggerMode_)
boolean tmp = PIND & inPinBit_;
if (tmp != triggerState_)
if (blankOnHigh_ && tmp )
PORTB = 0;
else if (!blankOnHigh_ && !tmp )
PORTB = 0;
if (triggerNr_ >= 0)
PORTB = triggerPattern_[sequenceNr_];
sequenceNr_++;
if (sequenceNr_ >= patternLength_)
sequenceNr_ = 0;
triggerNr_++;
triggerState_ = tmp;
else if (blanking_)
if (blankOnHigh_)
if (! (PIND & inPinBit_))
PORTB = 0;
PORTB = 0;
bool waitForSerial(unsigned long timeOut)
unsigned long startTime = millis();
while (Serial.available() == 0 && (millis() - startTime < timeOut) ) {}
return true;
return false;
// Sets analogue output in the TLV5618
// channel is either 0 ('A') or 1 ('B')
// value should be between 0 and 4095 (12 bit max)
// pins should be connected as described above
void analogueOut(int channel, byte msb, byte lsb)
digitalWrite(latchPin, LOW);
msb &= B00001111;
if (channel == 0)
msb |= B10000000;
// Note that in all other cases, the data will be written to DAC B and BUFFER
shiftOut(dataPin, clockPin, MSBFIRST, msb);
shiftOut(dataPin, clockPin, MSBFIRST, lsb);
// The TLV5618 needs one more toggle of the clockPin:
digitalWrite(clockPin, HIGH);
digitalWrite(clockPin, LOW);
// This function is called through an interrupt
void triggerMode()
if (triggerNr_ >=0) {
sequenceNr_++;
sequenceNr_ = 0;
triggerNr_++;
void blankNormal()
if (DDRD & B00000100) {
} else
PORTB = 0;
void blankInverted()
PORTB = 0;
The code looks like a Fimata-alike.
(I have no idea what MicroManager is, though I used to have one)
Each command starts with one binary byte containing the command code. See the comments at the beginning of the sketch for the list of command codes and what they do.
switch (inByte)
Micro-Manager is an open-source program that basically helps control microscopy procedures. The aim of the project is to use MM to trigger the arduino for faster communication between the components
I read through them, but I wasn't really able to understand their exact purpose. As far as I could tell, each byte refers to a sequence that triggers pins from D8 to D13, depending on the sequence
Is Fimata a certain type of coding in Arduino?
Also, there is one difference that needs to be made in the code, that I am aware, which does not break it, is that the baud rate needs to be 9600, not 57600. So,
will be
I also wanted to ask what's the exact use of this bit:
Because I need the analog ports to act as output, not input. I do know this is a way to refer to all analog ports in one go, but I don't know how to change these values so that that A0 through A5 act as 5V outputs
Ans: To connect the internal pull-up resistor with an input line (Fig-1). In your case, all six IO lines (PC0/A0-PC5/A5) of Port-C of the UNO Board will work as input lines with their respective internal pull-up resistor connected.
How?
1. There are pull-up resistors inside the ATmega328P MCU of the UNO Board (Fig-1). These pull-up resistors can be connected only with the input lines.
Fgure-1:
2. To set the direction of an IO line as an input 0 (LOW) is written into the corresponding bit of the DDR (Data Direction Register). The execution of the following line puts 000000 on DDRC to make PC0 - PC5 (A0 - A5) as input lines:
As a result, 2nd input of the AND gate receives 0 which after inversion becomes 1.
3. The execution of the following line puts 111111s on the internal PORTC latch (Fig-1).
As a result, 3nd input of the AND gate receives 1.
4. Finally, the PUD (Power Up Disable) bit which is 0 at power-up. It is connected with the 1st input of the AND gate. After inversion, it becomes 1.
5. Eventually AND gate is ON which in turn makes the MOSFET ON; as a result the intrenal pull-up resistor gets connected with an input line.
6. All the above tasks (Step-1 to 5) can b done by executing the following line:
pinMode(A0, INPUT_PULLUP); //for PC0/A0 line
Equivalent to:
pinMode(A1, INPUT_PULLUP);
pinMode(A2, INPUT_PULLUP);
pinMode(A3, INPUT_PULLUP);
pinMode(A4, INPUT_PULLUP);
pinMode(A5, INPUT_PULLUP);
So, PORT C refers to the analog ports, right? What do PORT A and PORT B refer to?
There is no PORTA. There used to be, on the ATmega8. It was a 40 pin chip and had four full 8-bit ports. PORTA was the analog inputs. PORTB, PORTC, and PORTD were digital ports.
ATmega328P chip only has 28 physical pins so there is no wy to keep all 32 functions on separate pins. They eliminated PORTA and put the analog inputs as a secondary function of PORTC. PORTD contains Arduino UNO/Nano pins 0 through 7 and PORTB contains Arduino UNO/Nano pins 8 through 13.
Ok. So, what changes would I need to make to this to have the analog ports function as outputs, instead of inputs? Because I need the analog ports to send a trigger signal when the UNO board receives an input trigger signal from an external device, say, an arbitrary function generator.
Change this:
to this:
Then change any inputs you want to outputs.
