Help understanding mDNS on ESP32
I'm running the mDNS-SD Extended example on two ESP32 boards.
The instructions tell me
Instructions:
  • Update WiFi SSID and password as necessary.
  • Flash the sketch to two ESP8266 boards
  • The last one powered on should now find the other.
Neither finds any response.
Yet if I run the mDNS webserver example on one of the boards, the "mDNS-SD Extended" board finds
Browsing for service _http._tcp.local. ... 1 service(s) found
1: esp32 (192.168.1.49:80)
Browsing for service _arduino._tcp.local. ... 1 service(s) found
1: esp32 (192.168.1.49:3232)
Browsing for service _workstation._tcp.local. ... no services found
Am I misunderstanding something? I cant see where the mDNS-SD Extended example sets up a service for the other to find.
  ESP8266 mDNS-SD responder and query sample
  This is an example of announcing and finding services.
  Instructions:
  - Update WiFi SSID and password as necessary.
  - Flash the sketch to two ESP8266 boards
  - The last one powered on should now find the other.
#include <WiFi.h>
#include <ESPmDNS.h>
const char* ssid = "******";  // Enter SSID here
const char* password = "******";  //Enter Password here
    WiFi.begin(ssid, password);
        delay(250);
        Serial.print(".");
    Serial.println("");
    Serial.print("Connected to ");
    Serial.println(ssid);
    Serial.print("IP address: ");
    if (!MDNS.begin("ESP32_Browser")) {
        Serial.println("Error setting up MDNS responder!");
        while(1){
    browseService("http", "tcp");
    browseService("arduino", "tcp");
    browseService("workstation", "tcp");
    browseService("smb", "tcp");
    browseService("afpovertcp", "tcp");
    browseService("ftp", "tcp");
    browseService("ipp", "tcp");
    browseService("printer", "tcp");
    delay(10000);
void browseService(const char * service, const char * proto){
    Serial.printf("Browsing for service _%s._%s.local. ... ", service, proto);
    int n = MDNS.queryService(service, proto);
    if (n == 0) {
        Serial.println("no services found");
        Serial.print(n);
        Serial.println(" service(s) found");
        for (int i = 0; i < n; ++i) {
            // Print details for each service found
            Serial.print("  ");
            Serial.print(i + 1);
            Serial.print(": ");
            Serial.print(MDNS.hostname(i));
            Serial.print(" (");
            Serial.print(MDNS.IP(i));
            Serial.print(":");
            Serial.print(MDNS.port(i));
            Serial.println(")");
Could it be that the name should be unique? Just a stab in the dark.
If they are both browsing I don't see how this can work. I do not see in the code anyplace where it could even detect another esp. Maybe post the question to the esp32 forum on the espressif website.
The example sketch has not changed since it was added to GitHub over five years ago. If the instructions are wrong they were wrong from the beginning.
I see that the "mDNS_Web_Server" responds to "_arduino._tcp.local" even though the sketch does not add that service. I wonder where that comes from. My guess would be ArduinoOTA but I don't see that library included.
Sorry if its confusing John;
running the mDNS-SD Extended example on BOTH boards - neither finds the other.
Nor does my bonjour browser on my android phone, or Bonjourbrowser on windows.
While testing I uploaded THIS SKETCH (below) to one of the boards
(modified from the mDNS WebServer example)
which establishes these services
//add our services
mdns_service_add(NULL, "_http", "_tcp", 80, NULL, 0);
mdns_service_add(NULL, "_arduino", "_tcp", 3232, NULL, 0);
mdns_service_add(NULL, "_myservice", "_udp", 1234, NULL, 0);
which the mDNS-SD Extended example DOES detect. So the "detection" works; however
I dont see anywhere in the mDNS-SD Extended example that starts a service
Am I the first in 5 years to have tried this? Or is it a problem that the mDNS-SD Extended example is written for the esp8266?
  ESP32 mDNS responder sample
  This is an example of an HTTP server that is accessible
  via http://esp32.local URL thanks to mDNS responder.
  Instructions:
  - Flash the sketch to the ESP32 board
  - Install host software:
    - For Linux, install Avahi (http://avahi.org/).
    - For Windows, install Bonjour (http://www.apple.com/support/bonjour/).
    - For Mac OSX and iOS support is built in through Bonjour already.
  - Point your browser to http://esp32.local, you should see a response.
  * modified from the mDNS WebServer example
  * additional function examples from
  * https://espressif.github.io/esp-protocols/mdns/en/index.html
#include <WiFi.h>
#include <WiFiClient.h>
const char* ssid = "***********";  // Enter SSID here
const char* password = "*********";  //Enter Password here
// TCP server at port 80 will respond to HTTP requests
WiFiServer server(80);
//Example method to start mDNS for the STA interface and set hostname and default_instance:
void start_mdns_service()
    //initialize mDNS service
    esp_err_t err = mdns_init();
    if (err) {
        printf("MDNS Init failed: %d\n", err);
        return;
    //set hostname
    mdns_hostname_set("esp32-expt"); //
    //set default instance
    mdns_instance_name_set("ESP32 mDNS experiment");
//Example method to add a few services and different properties:
void add_mdns_services()
    //add our services
    //NOTE: services must be added before their properties can be set
    //use custom instance for the web server
    mdns_service_instance_name_set("_http", "_tcp", "John's ESP32 Web Server experiment");
    mdns_txt_item_t serviceTxtData[3] = {
        {"board","{esp32}"},
        {"u","user"},
        {"p","password"}
    //set txt data for service (will free and replace current data)
    mdns_service_txt_set("_http", "_tcp", serviceTxtData, 3);
    //change service port
    mdns_service_port_set("_myservice", "_udp", 4321);
//Example method to resolve host IPs:
void resolve_mdns_host(const char * host_name)
    printf("Query A: %s.local:  ", host_name);
    struct ip4_addr addr;
    addr.addr = 0;
    esp_err_t err = mdns_query_a(host_name, 2000,  &addr);
    if(err){
        if(err == ESP_ERR_NOT_FOUND){
            printf("Host was not found!\n");
            return;
        printf("Query Failed");
        return;
    printf(":   ");
    printf(IPSTR, IP2STR(&addr));
//Example method to resolve local services:
static const char * if_str[] = {"STA", "AP", "ETH", "MAX"};
static const char * ip_protocol_str[] = {"V4", "V6", "MAX"};
void mdns_print_results(mdns_result_t * results){
    mdns_result_t * r = results;
    mdns_ip_addr_t * a = NULL;
    int i = 1, t;
    while(r){
        printf("%d: Interface: %s, Type: %s\n", i++, if_str[r->tcpip_if], ip_protocol_str[r->ip_protocol]);
        if(r->instance_name){
            printf("  PTR : %s\n", r->instance_name);
        if(r->hostname){
            printf("  SRV : %s.local:%u\n", r->hostname, r->port);
        if(r->txt_count){
            printf("  TXT : [%u] ", r->txt_count);
            for(t=0; t<r->txt_count; t++){
                printf("%s=%s; ", r->txt[t].key, r->txt[t].value);
            printf("\n");
        a = r->addr;
        while(a){
            if(a->addr.type == IPADDR_TYPE_V6){
                printf("  AAAA: " IPV6STR "\n", IPV62STR(a->addr.u_addr.ip6));
                printf("  A   : " IPSTR "\n", IP2STR(&(a->addr.u_addr.ip4)));
            a = a->next;
        r = r->next;
void find_mdns_service(const char * service_name, const char * proto)
    ESP_LOGI(TAG, "Query PTR: %s.%s.local", service_name, proto);
    mdns_result_t * results = NULL;
    esp_err_t err = mdns_query_ptr(service_name, proto, 3000, 20,  &results);
    if(err){
        ESP_LOGE(TAG, "Query Failed");
        return;
    if(!results){
        ESP_LOGW(TAG, "No results found!");
        return;
    mdns_print_results(results);
    mdns_query_results_free(results);
//Example of using the methods above:
void my_app_some_method(){
    //search for esp32-mdns.local
    resolve_mdns_host("esp32-expt");
    //search for esp32.local
    resolve_mdns_host("esp32");
    //search for HTTP servers
    find_mdns_service("_http", "_tcp");
    //or file servers
    find_mdns_service("_smb", "_tcp"); //windows sharing
    find_mdns_service("_afpovertcp", "_tcp"); //apple sharing
    find_mdns_service("_nfs", "_tcp"); //NFS server
    find_mdns_service("_ftp", "_tcp"); //FTP server
    //or networked printer
    find_mdns_service("_printer", "_tcp");
    find_mdns_service("_ipp", "_tcp");
void setup(void)
    // Connect to WiFi network
    Serial.println("");
    // Wait for connection
        Serial.print(".");
    Serial.println("");
    Serial.println(" ");
    Serial.println("ESP32 mDNS experiment: mDNS hostname is esp32-expt");
    // Set up mDNS responder:
    // - first argument is the domain name, in this example
    //   the fully-qualified domain name is "esp32.local"
    // - second argument is the IP address to advertise
    //   we send our IP address on the WiFi network
    if (!MDNS.begin("esp32")) {
        while(1) {
    Serial.println("mDNS responder started");
    start_mdns_service();
    // Start TCP (HTTP) server
    server.begin();
    Serial.println("TCP server started");
    // Add service to MDNS-SD
    //MDNS.addService("http", "tcp", 80);
    add_mdns_services();
    my_app_some_method();
void loop(void)
    // Check if a client has connected
    WiFiClient client = server.available();
    if (!client) {
        return;
    Serial.println("");
    Serial.println("New client");
    // Wait for data from client to become available
    while(client.connected() && !client.available()){
        delay(1);
    // Read the first line of HTTP request
    String req = client.readStringUntil('\r');
    // First line of HTTP request looks like "GET /path HTTP/1.1"
    // Retrieve the "/path" part by finding the spaces
    int addr_start = req.indexOf(' ');
    int addr_end = req.indexOf(' ', addr_start + 1);
    if (addr_start == -1 || addr_end == -1) {
        Serial.print("Invalid request: ");
        Serial.println(req);
        return;
    req = req.substring(addr_start + 1, addr_end);
    Serial.print("Request: ");
    String s;
    if (req == "/")
        IPAddress ip = WiFi.localIP();
        String ipStr = String(ip[0]) + '.' + String(ip[1]) + '.' + String(ip[2]) + '.' + String(ip[3]);
        s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>Hello from ESP32 mDNS experiment  at ";
        s += ipStr;
        s += "</html>\r\n\r\n";
        Serial.println("Sending 200");
        s = "HTTP/1.1 404 Not Found\r\n\r\n";
        Serial.println("Sending 404");
    client.print(s);
    client.stop();
    Serial.println("Done with client");
