Hoping someone can help me understand my IR receiver code.
I'm using the example library called IRRemote->SimpleReceiver, and modified it slightly so that I can understand it better.
code here:
* SimpleReceiver.cpp
* Demonstrates receiving NEC IR codes with IRrecv
* This file is part of Arduino-IRremote https://github.com/Arduino-IRremote/Arduino-IRremote.
* MIT License
* Copyright (c) 2020-2022 Armin Joachimsmeyer
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is furnished
* to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
* INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
* PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
* HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
* CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
* OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
unsigned char DECODEDDATA;
* Specify which protocol(s) should be used for decoding.
* If no protocol is defined, all protocols are active.
//#define DECODE_DENON // Includes Sharp
//#define DECODE_JVC
//#define DECODE_KASEIKYO
//#define DECODE_PANASONIC // the same as DECODE_KASEIKYO
//#define DECODE_LG
#define DECODE_NEC // Includes Apple and Onkyo
//#define DECODE_SAMSUNG
#define DECODE_SONY
//#define DECODE_RC5
//#define DECODE_RC6
//#define DECODE_BOSEWAVE
//#define DECODE_LEGO_PF
//#define DECODE_MAGIQUEST
//#define DECODE_WHYNTER
//#define DECODE_DISTANCE // universal decoder for pulse width or pulse distance protocols
//#define DECODE_HASH // special decoder for all protocols
//#define DEBUG // Activate this for lots of lovely debug output from the decoders.
//#define INFO // To see valuable informations from universal decoder for pulse width or pulse distance protocols
#include <Arduino.h>
* Define macros for input and output pin etc.
#include "PinDefinitionsAndMore.h"
#include <IRremote.hpp>
// Just to know which program is running on my Arduino
Serial.println(F("START " __FILE__ " from " __DATE__ "\r\nUsing library version " VERSION_IRREMOTE));
// Start the receiver and if not 3. parameter specified, take LED_BUILTIN pin from the internal boards definition as default feedback LED
IrReceiver.begin(A0, ENABLE_LED_FEEDBACK);
Serial.print(F("Ready to receive IR signals of protocols: "));
printActiveIRProtocols(&Serial);
Serial.print(F("at pin "));
Serial.println(A0);
* Check if received data is available and if yes, try to decode it.
* Decoded result is in the IrReceiver.decodedIRData structure.
* E.g. command is in IrReceiver.decodedIRData.command
* address is in command is in IrReceiver.decodedIRData.address
* and up to 32 bit raw data in IrReceiver.decodedIRData.decodedRawData
if (IrReceiver.decode()) {
// Print a short summary of received data
IrReceiver.printIRResultShort(&Serial);
Serial.println(IrReceiver.decodedIRData.decodedRawData,HEX);
DECODEDDATA=IrReceiver.decodedIRData.decodedRawData,HEX;
Serial.println("vvv");
Serial.println(DECODEDDATA);
Serial.println("^^^");
if (IrReceiver.decodedIRData.protocol == UNKNOWN) {
// We have an unknown protocol here, print more info
//IrReceiver.printIRResultRawFormatted(&Serial, true);
* !!!Important!!! Enable receiving of the next value,
* since receiving has stopped after the end of the current received data packet.
IrReceiver.resume(); // Enable receiving of the next value
* Finally, check the received data and perform actions according to the received command
if (IrReceiver.decodedIRData.command == 0x10) {
// do something
} else if (IrReceiver.decodedIRData.command == 0x11) {
// do something else
I've added my own line in to try and see how to get the bit of code that I want.
When I use my remote, I receive results in the Serial Monitor as follows:
Protocol=SONY Address=0x1C5A Command=0x39 Repeat gap=12100us Raw-Data=0xE2D39 20 bits LSB first
E2D39
vvv
57
I really want to return this value in my DECODEDDATA variable:
0xE2D39
Even this value would be OK:
E2D39
But what i get is this:
57
What do I need to do to get either 0xE2D39 or E2D39 into the variable DECODEDDATA?
