Help understanding the code flow within the Alvik libraries
I'm attempting to learn more about the Arduino Alvik codebase.
Specifically, I'm trying to trace the code that executes when calling a drive() command, all the way to where the individual motors speeds are updated to make the bot drive.
My current understanding is that:
  • The Arduino Alvik is the primary Arduino library that is utilized within custom sketches to run on the Nano ESP32.
  • The Arduino Alvik Carrier is the firmware code that runs on the STM32
  • The Arduino Alvik library contains a high-level API with functions like drive() and move() that users can call in their sketches on the NanoESP32, and the low-level control of the motors is handed by the Arduino Alvik Carrier codeon the STM32
I'm trying to identify where the interaction is happening between the NanoESP32 and the STM32.
For example, this is the code that is executed for the drive() function:
void Arduino_Alvik::drive(const float linear, const float angular, const uint8_t linear_unit, const uint8_t angular_unit){
  if (angular_unit == PERCENTAGE){
    converted_angular = (angular/ROBOT_MAX_DEG_S)*100.0;
  else{
    converted_angular = convert_rotational_speed(angular, angular_unit, DEG_S);
  msg_size = packeter->packetC2F('V', convert_speed(linear, linear_unit, MM_S), converted_angular);
  uart->write(packeter->msg, msg_size);
Here linear and angular values are converted and written in a serial message over UART.
I'd expect this UART communication to be sent to the STM32, where it would read and parsed, to be used in the low-level motor control . However, I can't located where that may be happeing.
Instead, it looks like the reading and parsing (read_message() & parse_message()) is happening in the Arduino Alvik library itself, running on the NanoESP32.
The parsing of this drive message does the following:
    case 'v':
      while (!xSemaphoreTake(robot_vel_semaphore, 5)){}
      packeter->unpacketC2F(code, robot_velocity[0], robot_velocity[1]);
      xSemaphoreGive(robot_vel_semaphore);
Here the robot_velocity array values are updated with the linear and angular velocities.
So I'm still missing how these values are passed down further to the STM32 in order to control the motors.
Does anyone have any info on this?
With some further digging, it looks like my answers lie within the firmware.ino code, which looks to be the actual firmware code running on the STM32 and has the reading/parsing logic that I have been looking for
