Help understanding the MaxMatrix Library
Hi guys, I'm pretty new to this forum, I am currently working on a LED scrolling text using Arduino Uno and Max7219. I came across the MaxMatrix library and I am having a bit of trouble understanding it!
My current knowledge of C++ is very limited. I know about classes, function calls, the unary scope resolution operator, etc.
There are multiple things I dont udnerstand.
First:
byte data;
byte load;
byte clock;
etc..
they are stating what? what is a byte?
Second:
What does buffer do? I dont understand the concept behind the buffer.
Third:
What is the purpose of the reload?
Also, if you guys can give me a quick explanation of the whole code to make sure I understand it, it would be great! I think I understand most of it. Thanks!
// MaxMatrix.h <------ file
#ifndef _MaxMatrix_H_
#define _MaxMatrix_H_
#include "Arduino.h"
#define max7219_reg_noop        0x00
#define max7219_reg_digit0      0x01
#define max7219_reg_digit1      0x02
#define max7219_reg_digit2      0x03
#define max7219_reg_digit3      0x04
#define max7219_reg_digit4      0x05
#define max7219_reg_digit5      0x06
#define max7219_reg_digit6      0x07
#define max7219_reg_digit7      0x08
#define max7219_reg_decodeMode  0x09
#define max7219_reg_intensity   0x0a
#define max7219_reg_scanLimit   0x0b
#define max7219_reg_shutdown    0x0c
#define max7219_reg_displayTest 0x0f
class MaxMatrix
  private:
    byte data;
    byte load;
    byte clock;
    byte num;
    byte buffer[80];
    void reload();
  public:
    MaxMatrix(byte data, byte load, byte clock, byte num); // constructor
    void init();
    void clear();
    void setCommand(byte command, byte value);
    void setIntensity(byte intensity);
    void setColumn(byte col, byte value);
    void setColumnAll(byte col, byte value);
    void setDot(byte col, byte row, byte value);
    void writeSprite(int x, int y, const byte* sprite);
    void shiftLeft(bool rotate = false, bool fill_zero = true);
    void shiftRight(bool rotate = false, bool fill_zero = true);
    void shiftUp(bool rotate = false);
    void shiftDown(bool rotate = false);
#endif
// MaxMatrix.cpp <------ file
#include "MaxMatrix.h"
MaxMatrix::MaxMatrix(byte _data, byte _load, byte _clock, byte _num)
	data = _data;
	load = _load;
	clock = _clock;
	num = _num;
	for (int i=0; i<80; i++)
		buffer[i] = 0;
void MaxMatrix::init()
	pinMode(data,  OUTPUT);
	pinMode(clock, OUTPUT);
	pinMode(load,  OUTPUT);
	digitalWrite(clock, HIGH);
	setCommand(max7219_reg_scanLimit, 0x07);
	setCommand(max7219_reg_decodeMode, 0x00);  // using an led matrix (not digits)
	setCommand(max7219_reg_shutdown, 0x01);    // not in shutdown mode
	setCommand(max7219_reg_displayTest, 0x00); // no display test
	// empty registers, turn all LEDs off
	clear();
	setIntensity(0x0f);    // the first 0x0f is the value you can set
void MaxMatrix::setIntensity(byte intensity)
	setCommand(max7219_reg_intensity, intensity);
void MaxMatrix::clear()
	for (int i=0; i<8; i++)
		setColumnAll(i,0);
		buffer[i] = 0;
void MaxMatrix::setCommand(byte command, byte value)
	digitalWrite(load, LOW);
	for (int i=0; i<num; i++)
		shiftOut(data, clock, MSBFIRST, command);
		shiftOut(data, clock, MSBFIRST, value);
	digitalWrite(load, HIGH);
void MaxMatrix::setColumn(byte col, byte value)
	int n = col / 8;
	int c = col % 8;
		if (i == n)
			shiftOut(data, clock, MSBFIRST, c + 1);
			shiftOut(data, clock, MSBFIRST, 0);
	buffer[col] = value;
void MaxMatrix::setColumnAll(byte col, byte value)
		shiftOut(data, clock, MSBFIRST, col + 1);
		buffer[col * i] = value;
void MaxMatrix::setDot(byte col, byte row, byte value)
    bitWrite(buffer[col], row, value);
	int n = col / 8;
	int c = col % 8;
		if (i == n)
			shiftOut(data, clock, MSBFIRST, buffer[col]);
void MaxMatrix::writeSprite(int x, int y, const byte* sprite)
	int w = sprite[0];
	int h = sprite[1];
	if (h == 8 && y == 0)
		for (int i=0; i<w; i++)
			int c = x + i;
			if (c>=0 && c<80)
				setColumn(c, sprite[i+2]);
			for (int j=0; j<h; j++)
				int c = x + i;
				int r = y + j;
				if (c>=0 && c<80 && r>=0 && r<8)
					setDot(c, r, bitRead(sprite[i+2], j));
void MaxMatrix::reload()
		int col = i;
		for (int j=0; j<num; j++)
			shiftOut(data, clock, MSBFIRST, i + 1);
			col += 8;
void MaxMatrix::shiftLeft(bool rotate, bool fill_zero)
	byte old = buffer[0];
	int i;
	for (i=0; i<80; i++)
		buffer[i] = buffer[i+1];
	if (rotate) buffer[num*8-1] = old;
	else if (fill_zero) buffer[num*8-1] = 0;
	reload();
void MaxMatrix::shiftRight(bool rotate, bool fill_zero)
	int last = num*8-1;
	byte old = buffer[last];
	int i;
	for (i=79; i>0; i--)
		buffer[i] = buffer[i-1];
	if (rotate) buffer[0] = old;
	else if (fill_zero) buffer[0] = 0;
	reload();
void MaxMatrix::shiftUp(bool rotate)
	for (int i=0; i<num*8; i++)
		bool b = buffer[i] & 1;
		buffer[i] >>= 1;
		if (rotate) bitWrite(buffer[i], 7, b);
	reload();
void MaxMatrix::shiftDown(bool rotate)
		bool b = buffer[i] & 128;
		buffer[i] <<= 1;
		if (rotate) bitWrite(buffer[i], 0, b);
	reload();
Check out the parola.h library as well.
https://parola.codeplex.com/
C++ terms, google them. Too basic to explain here.
Hi, I just downloaded the MaxMatrix library from gitHub. once I open and include the library, it shows me an error : MaxMatrix.h: No such file or directory. help me!
