Help understanding this inputs and outputs
Outputs cannot float. They are either HIGH (source current) or LOW (sink current). If you see a pull up or pull down resistor on an output, the resistor is probably there to keep the pin in a known state while the pin is an input (default state) during reset. The pull down on a MOSFET gate is an example of that use.
