Help Understanding This Program
Beware: If you get frustrated with overambitious newbies do not continue.
Can someone please explain this code top to bottom? It was written by this guy. It includes these libraries:
PID
LMotorController
I2Cdev
MPU6050
Please explain the reason for every line being there in simpler terms than they already.
Here it is:
(it is for a self-balancing robot)
#include <PID_v1.h>
#include <LMotorController.h>
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
 #include "Wire.h"
#endif
#define MIN_ABS_SPEED 30
MPU6050 mpu;
// MPU control/status vars
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorFloat gravity; // [x, y, z] gravity vector
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
//PID
double originalSetpoint = 172.50;
double setpoint = originalSetpoint;
double movingAngleOffset = 0.1;
double input, output;
//adjust these values to fit your own design
double Kp = 60;
double Kd = 2.2;
double Ki = 270;
PID pid(&input, &output, &setpoint, Kp, Ki, Kd, DIRECT);
double motorSpeedFactorLeft = 0.6;
double motorSpeedFactorRight = 0.5;
//MOTOR CONTROLLER
int ENA = 5;
int IN1 = 6;
int IN2 = 7;
int IN3 = 9;
int IN4 = 8;
int ENB = 10;
LMotorController motorController(ENA, IN1, IN2, ENB, IN3, IN4, motorSpeedFactorLeft, motorSpeedFactorRight);
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
void dmpDataReady()
 mpuInterrupt = true;
 // join I2C bus (I2Cdev library doesn't do this automatically)
 Wire.begin();
 TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
 #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
 Fastwire::setup(400, true);
 #endif
 mpu.initialize();
 devStatus = mpu.dmpInitialize();
 // supply your own gyro offsets here, scaled for min sensitivity
 mpu.setXGyroOffset(220);
 mpu.setYGyroOffset(76);
 mpu.setZGyroOffset(-85);
 mpu.setZAccelOffset(1788); // 1688 factory default for my test chip
 // make sure it worked (returns 0 if so)
 if (devStatus == 0)
 // turn on the DMP, now that it's ready
 mpu.setDMPEnabled(true);
 // enable Arduino interrupt detection
 attachInterrupt(0, dmpDataReady, RISING);
 mpuIntStatus = mpu.getIntStatus();
 // set our DMP Ready flag so the main loop() function knows it's okay to use it
 dmpReady = true;
 // get expected DMP packet size for later comparison
 packetSize = mpu.dmpGetFIFOPacketSize();
 //setup PID
 pid.SetMode(AUTOMATIC);
 pid.SetSampleTime(10);
 pid.SetOutputLimits(-255, 255);
 // ERROR!
 // 1 = initial memory load failed
 // 2 = DMP configuration updates failed
 // (if it's going to break, usually the code will be 1)
 Serial.print(F("DMP Initialization failed (code "));
 Serial.print(devStatus);
 Serial.println(F(")"));
 // if programming failed, don't try to do anything
 if (!dmpReady) return;
 // wait for MPU interrupt or extra packet(s) available
 while (!mpuInterrupt && fifoCount < packetSize)
 //no mpu data - performing PID calculations and output to motors
 pid.Compute();
 motorController.move(output, MIN_ABS_SPEED);
 // reset interrupt flag and get INT_STATUS byte
 // get current FIFO count
 fifoCount = mpu.getFIFOCount();
 // check for overflow (this should never happen unless our code is too inefficient)
 if ((mpuIntStatus & 0x10) || fifoCount == 1024)
 // reset so we can continue cleanly
 mpu.resetFIFO();
 Serial.println(F("FIFO overflow!"));
 // otherwise, check for DMP data ready interrupt (this should happen frequently)
 else if (mpuIntStatus & 0x02)
 // wait for correct available data length, should be a VERY short wait
 while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
 // read a packet from FIFO
 mpu.getFIFOBytes(fifoBuffer, packetSize);
 // track FIFO count here in case there is > 1 packet available
 // (this lets us immediately read more without waiting for an interrupt)
 fifoCount -= packetSize;
 mpu.dmpGetQuaternion(&q, fifoBuffer);
 mpu.dmpGetGravity(&gravity, &q);
 mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
 input = ypr[1] * 180/M_PI + 180;
Which lines don't you understand?
I don't understand the libraries themselves.
Do you understand the engineering principles that enable a self balancing robot is made to balance?
If not I suggest you read about that because then you will have a lot of background info that will help you understand the program.
Next question ... do you know how the MPU sensor works?
If not read up about that - you can probably download the device's datasheet.
And then ... do you know (again, in engineering terms) how PID control works?
If not, read up about that.
See how I am breaking the learning down into manageable pieces.
To be honest if someone was prepared to take the trouble to write a line-by-line explanation of the program you posted I don't think it would make sense without the knowledge I have mentioned above.
...R
I don't really understand anything through the "MPU control/status variables."
So, do lines like the following give you trouble (we need to calibrate ourselves to your level of understanding)?
With what Robin said, I don't understand how the MPU sensor works or how PID works either. I'll read up on those.
Thanks
PureStress:
With what Robin said, I don't understand how the MPU sensor works or how PID works either. Can you supply me with a website to read up on those?
Thanks
Have you Googled it?
OK, I now understand the MPU-6050 and PID.
On the other hand, I've never been on Github, so can someone teach me how to find the list of functions for each of the libraries? I think that's what's throwing me off.
Thanks
PureStress:
OK, I now understand what Robin was saying. I've never been on Github,
To be clear, the learning that I was recommending in Reply #3 for points 1 and 3 has nothing to do with programming and won't be found on Github. Try Wikipedia and then follow up the links it has and use what you learn from Wikipedia to help you formulate more specific Google searches.
And, as I said, the info for point 2 will be found in the relevant datasheet.
...R
OK, I understand everything besides the lines using the functions from the MPU6050 library. I can't find a list online of what each of the functions does. Does anyone know of a site that has them?
Thanks again.
PureStress:
I am not familiar with it myself so I can't help.
Unfortunately it is a common feature of Open Source software that the authors prefer writing code to writing documentation.
Try reading the source code for the library - there may be sufficient comments in it to help you figure things out. Start with the .h and the ,cpp files. However I suspect the device requires some complex maths to get useful data.
Another thought is to study the manufacturer's datasheet for the actual device.
...R
