Hi to all,
I'm having problems to understand how this code works.
It basically receives data from the RS232 and then forward them to the RS485.
If it receives nothing, it outputs 0 in all the registers.
I need to modify it in order to output -1 if it received nothing.
I cannot understand the line where this instruction is set.
I was expecting to see something like:
"if I receive nothing, then set everything to 0"
But I cannot find this instruction in the code.
If I upload the code into Arduino, I actually receive zero on the RS485 even if I have nothing from the Serial port. I need to set it at -1 when I receive nothing.
Can you help me, please?
#include <modbus.h>
#include <modbusDevice.h>
#include <modbusRegBank.h>
#include <modbusSlave.h>
modbusDevice regBank;
modbusSlave slave;
#define RS485TxEnablePin 2
#define RS485Baud 9600
#define RS485Format SERIAL_8E1
Serial1.begin(115200); //dati in ingresso da ESP01
Serial2.begin(115200); //dati in uscita da ATMEGA
//Serial.begin(9600);
regBank.setId(1);
//Add Analog Input registers to the register bank
regBank.add(30001);
regBank.add(30002);
regBank.add(30003);
regBank.add(30004);
regBank.add(30005);
regBank.add(30006);
regBank.add(30007);
regBank.add(30008);
regBank.add(30009);
regBank.add(30010);
regBank.add(30011);
regBank.add(30012);
regBank.add(30013);
regBank.add(30014);
regBank.add(30015);
slave._device = ®Bank;
slave.setBaud(&Serial, RS485Baud, RS485Format, RS485TxEnablePin);
//myStringC = builds(random(1,100));
if (Serial1.available() > 0) {
String rawData = Serial1.readStringUntil('\n'); //Reads data from ESP8266
int data = rawData.toInt(); //Turns data to integer
if(data>31){ //Filters none needed data
char c = data; //Converts data to readable string
myString+=c; //Combines string to form one command
if(data==13){ //When done recieving data
//Serial.println(myString); //Print received datamyString.remove(0, 1);
Serial2.println(myString); //Print received data
lun = myString.length();
if (lun>0){
for (i = 0; i < lun; i++) {
if (myString[i] == ',') {
stp = myString.substring(dd, i);
//Serial.print("substprima ");
//Serial.println(stp);
val = stp.toInt();
regBank.set(StartReg, val); //from 0 - 1023
//myval[ind] = val; //from 0 - 1023
//Serial.print("val ");
//Serial.println(val);
sta = myString.substring(i + 1);
//Serial.print("substdopo ");
//Serial.println(sta);
ind = ind + 1;
dd = i + 1;
StartReg = StartReg + 1;
if (myString[i] == ';') {
val = sta.toInt();
//Serial.print("ultimo ");
//slave.run();
//delay(1000);
myString="";
slave.run();
StartReg = 30001;
dd = 0;
ind = 0;
//i = 0;
//myStringC[15] = 0;
