[HELP] Unknown Errors
Hello there, I’ve a project using arduino uno & shield and lot of sensors (most of them connected with i2c)
and i’m creating a program which regroup in a sd card all the data collected through the sensors.
But arduino compilator is telling me there is some errors BUT when I revise them, some other “stranges” errors appears !
There is my program can you tell me what am I doing wrong please ?
#include<SD.h>
#include<SPI.h>
#include<Wire.h>
int address_sensor1= 72; //binary equivalent is 1001000
int address_sensor2= 73; //binary equivalent is 1001001
int address_sensor3= 74; //binary equivalent is 1001100
int address_sensor4= 75; //binary equivalent is 1001101
File Data;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Wire.begin();
if (!SD.begin(4)) {
Serial.println(“Initialisation impossible !”);
return;
Serial.println(“Initialisation OK.”);
// Check to see if the file exists:
if (!SD.exists(“Data.txt”)) {
Serial.println(“Data.txt existe.”);
else {
Serial.println(“Data.txt n’existe pas.”);
Serial.println(“Création de Data.txt…”);
Data = SD.open(“Data.txt”, FILE_WRITE);
Data.close();
if (Data) {
Serial.print(“Ecriture sur Data.txt…”);
Data.println(“Test 1, 2, 3.”);
// close the file:
Data.close();
Serial.println(“OK.”);
else {
// if the file didn’t open, print an error:
Serial.println(“Erreur d’ouverture du Data.txt”);
{ Wire.requestFrom(4, 6); // request 6 bytes from slave device #4
while (Wire.available()) { // slave may send less than requested
char c = Wire.read(); // receive a byte as character
Serial.print(c); // print the character
Wire.beginTransmission(address_sensor1); //Send a request to begin communication with the device at the specified address
Wire.write(0); //Sends a bit asking for register 0, the data register of the TC74 sensor
Wire.endTransmission(); //this ends transmission of data from the arduino to the temperature sensor
//this now reads the temperature from the TC74 sensor
Wire.requestFrom(address_sensor1, 1);//this requests 1 byte from the specified address
while(Wire.available() == 0);
int celsius1= Wire.read();
Serial.print(celsius1)}
// make a string for assembling the data to log:
String dataString = “”;
// read three sensors and append to the string:
dataString += String(celsius1)
delay(2000);
Thank a lot !
ma04nu: There is my program can you tell me what am I doing wrong please ?
You didn't read the sticky threads at top.
Ask for some data. While there is data to read, send a request for data. Really? Do you know what you are doing?
