Hi all,
I have made a custom arduino board using an atmega2560 and I'm at the point where I am trying to put the bootloader on it and then load a sketch. However when trying to load the bootloader, I am getting an error about the device signature.
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
Here is my procedure:
Load ArduinoISP sketch to my Uno
Connect uno to mega
Uno 10 to Mega reset
Uno 11 to Mega 51
Uno 12 to Mega 50
Uno 13 to Mega 52
Uno VCC to Mega VCC
Uno GND to Mega GND
Tools --> Board --> Mega 2560
Tools --> Programmer --> Arduino as ISP
Tools --> Burn bootloader
I'll attach a screenshot of my PCB.
If there's anything I'm doing wrong, please help!
Thanks,
Emanuel
whole board3.zip (102 KB)
Post the schematic.
I see from the routing: no decoupling caps on the VCC pins, ICSP socket looks different from the standard:
Pinout seen from above:
MISO 1 6 VCC
SCK 2 5 MOSI
Reset 3 4 GND
Vias to go thru the board look very close from the 2nd picture, could be shorting out?
You could have asked for a review here before purchasing boards.
ICSP socket is not standard, I'm just doing it with dupont wires to my arduino. The vias are close, but not touching. Verified with continuity. I should have asked for review, but based on my research this should be fine. The decoupling caps are the only thing, but I do have an output cap from the power reg IC. It's a 10uF between the 5v and gnd. Is this not sufficient? Seems like it's close enough distance-wise to the chip. Would the decoupling caps be causing such a big issue? Either way, I'm using the VCC from my Uno to power it at the moment so it shouldn't even be relevant right?
I wish I could post a helpful schematic, but I never actually organized it and made it look nice in Fritzing. I really just focused on the PCB view. I've uploaded the file in the original post if you want to take a look since I can't seem to upload it to my response here.
