[HELP]Use arduino to select address lines for HT12E and outputs
Hello friends, I am new to arduino and C. I am finding it difficult to select address lines and data lines for HT12E(Encoder IC).
Right now I am using a Raspberry Pi to select address lines for HT12E with a DIP switch and every time I must physically change the address to communicate to the decoder(s).
I am trying to use digitalWrite and digitalRead in switch case and loops from the given examples and references from this site and also did some searching and the result could not help me. Can you guys help me out?
Current code that I am working on, doesn't seem to work. If you guys can clear the bug in this code I can code for HT12E.
    int a= 2;
    int b = 1;
    int c = 6;
    int d = 5;
    void setup(){
      pinMode(a, INPUT);
      pinMode(b, INPUT);
      pinMode(c, OUTPUT);
      pinMode(d,OUTPUT);
    void loop(){
      int state = HIGH;
      int one = digitalRead(a==HIGH);
      int two = digitalRead(b==HIGH);
      switch(state){
        case 'one':
          digitalWrite(c,HIGH);
        case 'two':
          digitalWrite(d,HIGH);
BUMP
What is this crap? You are reading from one pin of a is HIGH and from another pin of a is LOW. How does that make any sense? You are doing the same with the second read, reading from the same two pins if b is HIGH or LOW.
Since a and b have fixed values (not HIGH and HIGH respectively), you are always reading from pins 0 ans 1.
