My aim is to measure the rotations of a winch using a rotary encoder and use a toggle switch (or should i use a momentary switch) to set a limit at the current encoder reading. There will be 3 display LEDs red, green, and yellow which I would like to use as indicators. Green it is far away from the limit, yellow it is getting close, and at red it cuts a relay off that is running the winch so it wont be able to go past the set limit. I am using a 7 segment display to show the values of the encoder and that portion of the code works. Any help would be appreciated, when i run the code the green Led should come on and it doesn't, and the it seems to be really buggy.
/* Encoder-7 seg Display Program
* This program is designed by Rip Martin on 11/8/2013
* This program is proprietary and should not be used
* or sold without the written consent of the creator.
#include <Encoder.h> // Includes the Encoder library, need to download
#include <SoftwareSerial.h> // Includes the Software Serial library
SoftwareSerial Serial7Segment(7, 8); // RX pin, TX pin
Encoder myEnc(2, 3); // Pins 2,3
int redLed = 4; // Red LED pin (output)
int greLed = 5; // Green LED pin (output)
int topSwitch = 9; // Top limit toggle switch (input)
int botSwitch = 10; // Bottom limit toggle switch (input)
int limitTop = -5; // Top (Start) limit position
int limitBot = 10000; // Bottom (End) Limit position
int saftey = 0;
boolean tSwitch = false;
boolean bSwitch = false;
Serial.println("Basic Encoder Test:");
pinMode(redLed, OUTPUT);
pinMode(greLed, OUTPUT);
pinMode(topSwitch, INPUT);
pinMode(botSwitch, INPUT);
redLed = LOW;
greLed = HIGH;
Serial7Segment.begin(9600); // Talk to the Serial7Segment at 9600 bps
Serial7Segment.write('v'); // Reset the display - this forces the cursor
// to return to the beginning of the display
long oldPosition = -999;
long newPosition = myEnc.read()/800;
char tempString[10]; //Used for sprintf
sprintf(tempString, "%4d", newPosition); // right adjusted
if (newPosition != oldPosition) {
oldPosition = newPosition;
Serial.println(newPosition);
Serial7Segment.print(tempString); //Send serial string out
if (digitalRead(topSwitch) == HIGH){
if(tSwitch == false){
tSwitch = !tSwitch;
limitTop = myEnc.read();
Serial.println("Top Limit Set At:");
Serial.println(limitTop/800);
else{
tSwitch = false;
if (digitalRead(botSwitch) == HIGH){
if(bSwitch == false){
bSwitch = !bSwitch;
limitBot = myEnc.read();
Serial.println("Bottom Limit Set At:");
Serial.println(limitBot/800);
else{
bSwitch = false;
if (digitalRead(topSwitch == HIGH) && digitalRead(botSwitch == HIGH)){
saftey = myEnc.read();
if (saftey >= limitTop && saftey <= limitBot){
greLed = HIGH;
redLed = LOW;
else if (saftey < limitTop || saftey > limitBot){
greLed = LOW;
redLed = HIGH;
if (digitalRead(topSwitch == LOW) || digitalRead(botSwitch) == LOW){
tSwitch = false;
bSwitch = false;
... //code to set top limit
... //code to set bottom limit
... // code for normal operation?
I think two of the instances of HIGH in that code should be LOW instead. Which ones depends on how you have wired the switches.
I have both switches connected the same way, one side to the +5 rail on the bread board and the other side of the switch going to the appropriate pin so the when it is on it pulls the pin high
Then surely you should execute the code that updates redLed and greLed when both switches read LOW, instead of when both switches read HIGH.
Also, instead of assigning new values to redLed and greLed, you need to digitalWrite the required value to those pins. Like this:
//**************** added const to the followng 4 lines
const int redLed = 4; // Red LED pin (output)
const int greLed = 5; // Green LED pin (output)
const int topSwitch = 9; // Top limit toggle switch (input)
const int botSwitch = 10; // Bottom limit toggle switch (input)
int saftey = 0;
//**************** changed the following 2 lines
digitalWrite(redLed, LOW);
digitalWrite(greLed, HIGH);
tSwitch = !tSwitch;
else{
tSwitch = false;
bSwitch = !bSwitch;
else{
bSwitch = false;
//************** changed HIGH to LOW twice in the following line
if (digitalRead(topSwitch == LOW) && digitalRead(botSwitch == LOW)){
//*************** changed the following 2 lines
digitalWrite( redLed, LOW);
//****************** changed the following 2 lines
digitalWrite(greLed, LOW);
digitalWrite(redLed, HIGH);
tSwitch = false;
bSwitch = false;
btw it's more usual to wire switches between the input pin and ground, then you avoid carrying +5V to the switch and you can use the internal pullup resistor.
I hope you are aware that such (simple) encoder can only indicate / count up / down rotation and by itself cannot give you absolute position, only relative to start.
So it really cannot "store a limit" per your specification.
But you could initialize it by always running to the start and let the limit switch at start reset the position to starting count.
