Hello, I need your help I am trying to do a simple program.. the setup is as follows: I have two arduinos one transmits via I2C to the other arduino.. and the recieving arduino displays the message on an LCD display.
I already have the i2Cup and running.. the code of the arduino that transmit the data is:
#include <Wire.h>
int x;
Wire.begin(); // join i2c bus (address optional for master)
Wire.beginTransmission(4); // transmit to device #4
Wire.send("TEST1 "); // sends six bytes
Wire.send(x); // sends int
Wire.endTransmission(); // stop transmitting
x++; //same: x=x+1;
delay(500); //
The problem is the receiving arduino.. the code of the recieving arduino is the following:
#include <Wire.h>
#include <LiquidCrystal.h> //include LiquidCrystal library
LiquidCrystal lcd = LiquidCrystal(); //create a LiquidCrystal object to control an LCD
char string1[] = "Hello!"; //variable to store the string "Hello!"
int ledPin = 13;
Wire.begin(4); // join i2c bus with address #4
Wire.onReceive(receiveEvent); // register event
Serial.begin(9600); // start serial for output
lcd.init(); //initialize the LCD
delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
digitalWrite(ledPin,HIGH); //turn on an LED for debugging
lcd.clear(); //clear the display
delay(1000); //delay 1000 ms to view change
lcd.printIn(string1); //send the string to the LCD
In theory when an event is recieved from the master arduino.. the slave arduino automatically jumps at the receivedEvent handler or rutine.. but this is ont happeningand i dont know why.. the only thing i get on my lcd display is a cursor because of the lcd.init code line at the setup..
any ideas why this doesnt work.. or do anybody knows a better way to do what i am trying to accomplish??
thanks in advance
