Hello all, I recently bought a couple of MCP23017 i2c port expanders from adafruit to drive 16 LEDs for my very first arduino project (a newbie). My inputs are 16 (maybe more) piezo sensors connected to the "mux shield". When a piezo is struck it sends a midi Note. So each sensor correlates to a specific notes and now I would like to add a LED to each sensor. I had previously tried a pcf8575 breakout board and found it to have a poor design and difficult to use.
Can someone show me how to use the Adafruit-MCP23017-Arduino-Library and MCP23017 - i2c 16 input/output port expander : ID 732 : $6.95 : Adafruit Industries, Unique & fun DIY electronics and kits MPC23017 to accomplish this.
A perfect example of what I'm trying to do is the midi_footsteps controller, which could be found here: MIDI Footsteps. I've got the multiplexers and midiOUT working thanks to Grumpy_mike, Crossroads and others in the Arduino forum. And now the final part is to add the LED section. Can anyone help me get this finale piece in place.
The library:
The data sheet:
The wiring:
The sketch goes like this: ( except no muxs are used here, in my actual project I'm using mux-shield i.e. 4051 multiplexers for up to 48 pads and the midi shield for midi OUT ) but you can get the basic idea. It's like a piano with keys that light up or a drum kit with pads that light up on inpact. So noteON = LED on.
// DESCRIPTION:
// Arduino analog input used to sense piezo drum hits then sent serialy to processing.
// User settable variables
unsigned char PadNote[6] = {52,16,66,63,40,65}; // MIDI notes from 0 to 127 (Mid C = 60)
int PadCutOff[6] = {600,600,600,600,600,600}; // Minimum Analog value to cause a drum hit
int MaxPlayTime[6] = {90,90,90,90,90,90}; // Cycles before a 2nd hit is allowed
#define midichannel 0; // MIDI channel from 0 to 15 (+1 in “real world”)
boolean VelocityFlag = true; // Velocity ON (true) or OFF (false)
// Internal Use Variables
boolean activePad[6] = {0,0,0,0,0,0}; // Array of flags of pad currently playing
int PinPlayTime[6] = {0,0,0,0,0,0}; // Counter since pad started to play
unsigned char status;
int pin = 0;
int hitavg = 0;
// Setup
Serial.begin(57600); // connect to the serial port 115200
// Main Program
for(int pin=0; pin < 6; pin++)
hitavg = analogRead(pin); // read the input pin
if((hitavg > PadCutOff[pin]))
if((activePad[pin] == false))
if(VelocityFlag == true)
// hitavg = 127 / ((1023 – PadCutOff[pin]) / (hitavg – PadCutOff[pin])); // With full range (Too sensitive ?)
hitavg = (hitavg / -1 ; // Upper range
hitavg = 127;
MIDI_TX(144,PadNote[pin],hitavg);
PinPlayTime[pin] = 0;
activePad[pin] = true;
PinPlayTime[pin] = PinPlayTime[pin] + 1;
else if((activePad[pin] == true))
if(PinPlayTime[pin] > MaxPlayTime[pin])
activePad[pin] = false;
MIDI_TX(128,PadNote[pin],127);
// Transmit MIDI Message
void MIDI_TX(unsigned char MESSAGE, unsigned char PITCH, unsigned char VELOCITY)
status = MESSAGE + midichannel;
Serial.print(status);
Serial.print(PITCH);
Serial.print(VELOCITY);
keyword: bitmasking
Thanks much.
