I am trying to switch a relay for 20 seconds then off but only when called from a html post. I have this working great when using delays however that then blocks LED pattern.
So my question is, I have a void relay1 i wont that to run for 20 seconds then and only after the time call void relay2
Thanks in advance!
void relay_1() {
currentMillis = millis();
startMillis = currentMillis;
if (currentMillis - startMillis >= period) {
digitalWrite(LED_BUILTIN, LOW);
server.sendHeader("Location", "/"); // Add a header to respond with a new location for the
void sTop() {
digitalWrite(LED_BUILTIN, HIGH);
browser to go to the home page again
server.send(303);
This test is never going to return true because currentMillis will always equal startMillis
You need to save the value of millis() as the start time when an action occurs then with loop() running freely, check each time through loop() whether the current time minus the start time equals or is greater than the required period
