Help using PS4 library to control a fan motor with a MOSFET (DIY Hovercraft)
Hello,
I am currenlty making a DIY remote control hovercraft. I am using the PS4 library to control the thrust fan and a servo motor for the rudder. The thrust fan is connected using a H-Bridge so the hovercraft can have reverse. Now I am at the point where I would like to connect my lift fan motors to my arduino and be able to turn it off and on using a MOSFET. The PS4 library has been quite straight forward to use but for some reason I can not figure out how to control my MOSFET with the click of a button. For example to control the direction of the thrust fan my code is: NOTE: [boolean thrust = true;]
if(PS4.getButtonClick(DOWN)){
if(fanDirection){
digitalWrite(in1,LOW);
digitalWrite(in2,HIGH);
fanDirection = !fanDirection;
delay(10);
}else if(!fanDirection){
digitalWrite(in1,HIGH);
digitalWrite(in2,LOW);
delay(10);
Now using a similar idea I thought I would be able to control the MOSFET but it does not seem to work. The first set of code I tried is: NOTE: [boolean lift = true; | int mos = 9;]
if(PS4.getButtonClick(UP)){
if(lift){
digitalWrite(mos,LOW);
else{
digitalWrite(mos,HIGH);
lift = !lift;
Unfortunatly I had no luck with this code so I though maybe I was over simplifying the problem. Therefore, I wrote this segment in hopes of an output:
if(PS4.getButtonClick(UP)){ // to start fan motor (but sadly would not even start)
So all in all I am wondering if any of you guys have any ideas on what I can do to be able to use the MOSFET as a virtual switch. Thanks for all the help!
PS. The circuit I am using works properly as I have tested it manually. It just doesn't seem to move once I try and use the controller as input.
Might be helpful to know which of the thousands of different MOSFETs and motors you have and how they are wired together.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html . Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
...and don't cross-post.
Duplicate deleted
