Help using servo motor with push button
Hello, I am really new to coding and arduino, I need help making a servo rotate 25 degrees when I push a button, and whenever I push the button again I want it to rotate 25 degrees more and so on. I only have this yet and it does not work, please help
#include <Servo.h>
int buttonState = 0;
Servo servo_9;
  pinMode(2, INPUT);
  servo_9.attach(9, 500, 2500);
  buttonState = digitalRead(2);
  if (buttonState == HIGH) {
    servo_9.write(25);
  delay(10);
Do you understand the difference between a "continuous rotation servo" and a normal servo ?
One of them will allow you to control only their rotation direction and speed, whilst the other will allow you to control their angle of rotation
Which type do you have do you think ?
I have a continuous rotation servo
Then you can only control only its rotation direction and speed, not its angle
The clue is in its name and, by the way, it is not really a servo at all
To position the output arm at a given angle, you will need a standard servo.
If I get a normal servo, am I gonna be able to make it rotate 25 degrees everytime I push a button?
Yes
EDIT : It has been pointed out to me that my simple answer may be confusing
Do you want the servo to move back and forth over a range of 25 degrees or always 25 degrees in the same direction ? If the latter, then a normal servo will not do that and you need a different solution such as a stepper motor
