Either you are not understanding
what all this means or you are ignoring it. You cannot connect ANY of these pins directly to an arduino running on 5V:Quote
sleepPin (pin-7)
selfTestPin (pin-13)
zeroGPin (pin-9)
gSelectPin (pin-10)
Well, you CAN. None of those 4 pins actually needs to be changed to use the device. You connect them either 0 or 1 depending on what you want to do. For 0, connect them to ground. For one, connect them to the 3.3 V pin on the arduino board. None of those pins actually needs to be connected to any pin of the Arduino which is going to try to put 5V into it.
