Help Using STEMMA Connector on Adafruit VL6180X
Hi, I currently do not have any access to a soldering iron to solder on the pins to my board but they do provide the STEMMA adaptors. I tried using the STEMMA adaptors but they end up showing me random characters on the serial monitor.
Do I have to add on to the code so that I can get the actual results?
I am currently just using the example code from the library.
#include <Wire.h>
#include "Adafruit_VL6180X.h"
Adafruit_VL6180X vl = Adafruit_VL6180X();
  // wait for serial port to open on native usb devices
  while (!Serial) {
    delay(1);
  Serial.println("Adafruit VL6180x test!");
  if (! vl.begin()) {
    Serial.println("Failed to find sensor");
    while (1);
  Serial.println("Sensor found!");
  float lux = vl.readLux(VL6180X_ALS_GAIN_5);
  Serial.print("Lux: "); Serial.println(lux);
  uint8_t range = vl.readRange();
  uint8_t status = vl.readRangeStatus();
  if (status == VL6180X_ERROR_NONE) {
    Serial.print("Range: "); Serial.println(range);
  // Some error occurred, print it out!
  if  ((status >= VL6180X_ERROR_SYSERR_1) && (status <= VL6180X_ERROR_SYSERR_5)) {
    Serial.println("System error");
  else if (status == VL6180X_ERROR_ECEFAIL) {
    Serial.println("ECE failure");
  else if (status == VL6180X_ERROR_NOCONVERGE) {
    Serial.println("No convergence");
  else if (status == VL6180X_ERROR_RANGEIGNORE) {
    Serial.println("Ignoring range");
  else if (status == VL6180X_ERROR_SNR) {
    Serial.println("Signal/Noise error");
  else if (status == VL6180X_ERROR_RAWUFLOW) {
    Serial.println("Raw reading underflow");
  else if (status == VL6180X_ERROR_RAWOFLOW) {
    Serial.println("Raw reading overflow");
  else if (status == VL6180X_ERROR_RANGEUFLOW) {
    Serial.println("Range reading underflow");
  else if (status == VL6180X_ERROR_RANGEOFLOW) {
    Serial.println("Range reading overflow");
  delay(50);
This looks like a baud rate mismatch.
Do you see any readable text in serial monitor? For testing, you can add a delay(5000) as the last line in setup() to see if you get readable data from setup().
@seiferturtlez
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
Apologies for repeating the question. I have taken note not to do this again in the future
I have done as mentioned. I received the first initial reading but the characters reappear again afterwards.
Screenshot 2023-09-27 203758
