Help /w PIR/servo project
Hey newbie here. I'm trying to make a project where servo points to the direction of movement detected by PIR sensor. Works just fine with 1 sensor but when I try to use 2 my servo just starts jerking between set states and won't stop. I'm using UNO, 9g servo and SR505 PIR.
Thanks for help!
My code :
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int led=13;                // the pin that the LED is atteched to
int ledPin = 13;                // choose the pin for the LED
int inputPin = 2;               // choose the input pin (for PIR sensor)
int inputPin1 = 4;              // choose the input pin (for PIR sensor1)
int pirState = LOW;             // we start, assuming no motion detected
int S = 0;                    // variable for reading the pin status
int S1 = 0;
  myservo.attach(9);
  pinMode(ledPin, OUTPUT);      // declare LED as output
  pinMode(inputPin, INPUT);     // declare sensor as input
  pinMode(inputPin1, INPUT);     // declare sensor as input
 myservo.write(0);
  delay(8000);                  //delay for PIR to setup
void loop(){
  PIR1();
  PIR2();
  CLR();
 void PIR1()  //PIR1 loop
  S = digitalRead(inputPin);  // read input value
  if (S == HIGH) {            // check if the input is HIGH
    digitalWrite(ledPin, HIGH);  // turn LED ON
    myservo.write(90);
    if (pirState == LOW) {
      // we have just turned on
      Serial.println("Motion detected sector 1!");
      // We only want to print on the output change, not state
      pirState = HIGH;
 void PIR2() //PIR2 loop
  S1 = digitalRead(inputPin1);  // read input value
  if (S1 == HIGH) {            // check if the input is HIGH
    myservo.write(180);
      Serial.println("Motion detected sector 2!");
      pirState = HIGH;
 void CLR() //No motion loop
   if (S == LOW && S1 == LOW) {            // check if the input is HIGH
    digitalWrite(ledPin, LOW); // turn LED OFF
    myservo.write(0);
    if (pirState == HIGH){
      // we have just turned of
      Serial.println("Motion ended!");
      pirState = LOW;
What made you think that your question has anything to do with the Website and Forum section which is clearly stated to be for "Improvements for the web system, applications to moderator, spam, etc."? I have suggested to the Moderator to move it to the Programming section.
This sort of carelessness makes unnecessary work for the Moderators.
Please read How to get the best out of the Forum
...R
