Help w/Seeedstudio GPRS Shields PLEASE!!!
I am having issues with the SeeedStudio shields returning truncated responses when sending read SMS commands and read phone book commands.
I am using an OSEPP Arduino Uno R3 Board(Purchased from Tiger Direct) and I own both version 1 and 2 of the SeeedStudio boards(
http://www.seeedstudio.com/depot/gprs-shield-v20-p-1379.html?cPath=132_134) with an ATT GoPro SIM. I am having these issues with both Shields. I am starting to wonder if AT&T is adding a specific format that's screwing up the responses. I plugged the SIM into my old IPhone 1 several times and the texts look fine.
The SIM is unlocked and I have been able to send texts from the Arduino using it.
When I use the AT COMMAND TESTERhttp://m2msupport.net/m2msupport/module-tester/ I can verify the SIM is working and connects to AT&T. However, when I issue the read SMS commands I get the message(s) back but the Data is formatted wrong and gets cut off like so:
AT+CMGL="ALL"
+CMGL: 1,"REC READ","+1817xxxxxxx","Nathan","13/07/01,22::t
+CMGL: 2,"REC UNREAD","+1817xxxxxxx","Nathan","13/07/0
OK
Sometimes I can see the partial text message but rarely.
My Code is using the basic example floating around online and I attached a screenshot of the AT Command Tester's results...
#include <SoftwareSerial.h>
SoftwareSerial mySerial(7,8);
  • mySerial.begin(19200); // the GPRS baud rate *
  • Serial.begin(19200); // the Serial port of Arduino baud rate.*
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
I use Arduino Uno R.3 / GPRS Shield V2.00.
I face the same problem : The text of SMS is incomplete (stop usualy after the date information) each time is always different.
I am fighting with it since more than 1 week, changing serial buffer size, baud rate, rebooting shield and arduino boards, ... but no result until now.
Some other people also fight with this, but no answer until now ... : check on "Seeduino Forum" Arduino Gprs Shield V2.0 and Duemilanove - #2 by aauffret - Project Proposal - Seeed Forum
Did you find the solution on your side ?
Thnaks a lot
