Hi folks,
I'm looking for an Arduino programmer to do what i think is 1-2 hrs of work modifying what looks like a very simple codebase. Details below. The code is at GitHub - robaux/swt16: Robaux SWT16 Firmware
Happy to pay (a little:).
Thanks!
-Bart
DETAILS:
I just purchased an Arduino based device, robaux.io - SWT16 - it's a drum machine encoder for Eurorack modular synthesizers.
The way the UI works is there is 1 button and you press the button to put the 16 encoders into a mode where they accept commands. So for instance press the button, that hold encoder 1 (row 1 column 1) to go into Step Edit mode. Then push encoder 1 again to select track 1. Then program your sequence using all 16 encoders.
Anyway, the menu system is slow and clunky. I would like to modify the UI so that it's faster/simpler, like so:
- while holding down the button, press on an encoder to select the track you want to edit. then edit the track. done.
Seems like it would be a pretty simple project, but I'm a terrible coder and don't know arduino.
Can I hire someone here for an hr or two to help?
