Hello All,
I built a ticker tape for stocks out of an esp8266 and ws2812b led strips which utilized thingspeak.com 's ThingHTTP app to pull stock data of of marketweatch.com. I had it working just as I wanted for a good while and could update the code to change which stocks it displayed data for based on which stocks I currently owned or was interested in monitoring and upload it to the the device no problem. Just the other day however, I went to upload the new code to the device and received errors which I amn not able to solve....
Here is the errors I receive and below that will be the complete code. Thanks for any help you may be able to offer.
C:\Users\15305\Documents\Arduino\StockTicker_esp2866\StockTicker_esp2866.ino: In function 'void stock_AR()':
StockTicker_esp2866:137:17: error: call to 'HTTPClient::begin' declared with attribute error: obsolete API, use ::begin(WiFiClient, host, port, uri)
137 | if (http.begin(host, httpPortRead, url1)) {
exit status 1
Exception in thread "Thread-20" java.lang.NullPointerException
at org.fife.ui.rsyntaxtextarea.TokenMakerBase.addToken(TokenMakerBase.java:136)
at processing.app.syntax.SketchTokenMaker.addToken(SketchTokenMaker.java:73)
at org.fife.ui.rsyntaxtextarea.TokenMakerBase.addToken(TokenMakerBase.java:110)
at org.fife.ui.rsyntaxtextarea.modes.CPlusPlusTokenMaker.addToken(CPlusPlusTokenMaker.java:1868)
at org.fife.ui.rsyntaxtextarea.modes.CPlusPlusTokenMaker.addToken(CPlusPlusTokenMaker.java:1852)
at org.fife.ui.rsyntaxtextarea.modes.CPlusPlusTokenMaker.addToken(CPlusPlusTokenMaker.java:1841)
at org.fife.ui.rsyntaxtextarea.modes.CPlusPlusTokenMaker.yylex(CPlusPlusTokenMaker.java:2241)
at org.fife.ui.rsyntaxtextarea.modes.CPlusPlusTokenMaker.getTokenList(CPlusPlusTokenMaker.java:1919)
at org.fife.ui.rsyntaxtextarea.RSyntaxDocument.getTokenListForLine(RSyntaxDocument.java:431)
at org.fife.ui.rsyntaxtextarea.SyntaxView.getLineWidth(SyntaxView.java:306)
at org.fife.ui.rsyntaxtextarea.SyntaxView.calculateLongestLine(SyntaxView.java:110)
at org.fife.ui.rsyntaxtextarea.SyntaxView.updateMetrics(SyntaxView.java:903)
at org.fife.ui.rsyntaxtextarea.SyntaxView.yForLine(SyntaxView.java:988)
at org.fife.ui.rsyntaxtextarea.SyntaxView.yForLineContaining(SyntaxView.java:1013)
at org.fife.ui.rsyntaxtextarea.RSyntaxTextAreaUI.yForLineContaining(RSyntaxTextAreaUI.java:263)
at org.fife.ui.rtextarea.RTextAreaBase.yForLineContaining(RTextAreaBase.java:1218)
at org.fife.ui.rtextarea.LineHighlightManager.repaintLine(LineHighlightManager.java:174)
at org.fife.ui.rtextarea.LineHighlightManager.addLineHighlight(LineHighlightManager.java:69)
at org.fife.ui.rtextarea.RTextArea.addLineHighlight(RTextArea.java:296)
at processing.app.Editor.addLineHighlight(Editor.java:1670)
at processing.app.Editor.statusError(Editor.java:2552)
at processing.app.Editor$UploadHandler.run(Editor.java:2083)
at java.lang.Thread.run(Thread.java:748)
[code]
#include <ESP8266WiFi.h> //Use ESP8266 functions
#include <WiFiClientSecure.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
const char* ssid = "ssid";
const char* password = "password"; //WIFI Password
const char* host = "api.thingspeak.com"; //We read the data from this host
const int httpPortRead = 80; // 3QGEILIH1SL6A5S8
const char* url1 = "/apps/thinghttp/send_request?api_key=G8RU6KUI89HLPPJ0"; //AR
int To_remove; //There are some irrelevant data on the string and here's how I keep the index
//of those characters
String Amount, Increase, Ratio, Data_Raw, Data_Raw_1, Data_Raw_2, Data_Raw_3;
WiFiClient client; //Create a WiFi client and http client
HTTPClient http;
#define stripPin 12
#define stripPinB 14
#define ledTotal 287 // zero indexed, so one less than you need. I.e. 50 leds = 49 here
#define ledTotalB // zero indexed...
#define rowSize 7 // zero indexed...
#define columnSize 35 // zero indexed...
#define charWidth 6 // ** one indexed **
byte displayOutput[columnSize + 1] = {0};
byte displayColors[columnSize + 1] = {0};
byte currentStatus = 0; // 0 = off, 1 = on
unsigned int maxLoad = 0;
int flag = 0;
int val = 0; // val will be used to store the state
// of the input pin
int old_val = 0; // this variable stores the previous
// value of "val"
int state = 0; // 0 = LED off and 1 = LED on
// was 68 with lower case chars, 42 without -- 40 without l/r arrow -- 42 WITH PLUS AND DOT
byte displayLetters[44][charWidth] = { // [A] = chars/digits contained in array, [B] = charWidth (no need to add 1, as was 'one indexed' at #define)
{0x3e, 0x51, 0x49, 0x45, 0x3e}, // 0 // , 0x00
{0x00, 0x42, 0x7f, 0x40, 0x00}, // 1
{0x42, 0x61, 0x51, 0x49, 0x46}, // 2
{0x21, 0x41, 0x45, 0x4b, 0x31}, // 3
{0x18, 0x14, 0x12, 0x7f, 0x10}, // 4
{0x27, 0x45, 0x45, 0x45, 0x39}, // 5
{0x3c, 0x4a, 0x49, 0x49, 0x30}, // 6
{0x01, 0x71, 0x09, 0x05, 0x03}, // 7
{0x36, 0x49, 0x49, 0x49, 0x36}, // 8
{0x06, 0x49, 0x49, 0x29, 0x1e}, // 9
{0x7e, 0x11, 0x11, 0x11, 0x7e}, // A
{0x7f, 0x49, 0x49, 0x49, 0x36}, // B
{0x3e, 0x41, 0x41, 0x41, 0x22}, // C
{0x7f, 0x41, 0x41, 0x22, 0x1c}, // D
{0x7f, 0x49, 0x49, 0x49, 0x41}, // E
{0x7f, 0x09, 0x09, 0x09, 0x01}, // F
{0x3e, 0x41, 0x49, 0x49, 0x7a}, // G
{0x7f, 0x08, 0x08, 0x08, 0x7f}, // H
{0x00, 0x41, 0x7f, 0x41, 0x00}, // I
{0x20, 0x40, 0x41, 0x3f, 0x01}, // J
{0x7f, 0x08, 0x14, 0x22, 0x41}, // K
{0x7f, 0x40, 0x40, 0x40, 0x40}, // L
{0x7f, 0x02, 0x0c, 0x02, 0x7f}, // M
{0x7f, 0x04, 0x08, 0x10, 0x7f}, // N
{0x3e, 0x41, 0x41, 0x41, 0x3e}, // O
{0x7f, 0x09, 0x09, 0x09, 0x06}, // P
{0x3e, 0x41, 0x51, 0x21, 0x5e}, // Q
{0x7f, 0x09, 0x19, 0x29, 0x46}, // R
{0x46, 0x49, 0x49, 0x49, 0x31}, // S
{0x01, 0x01, 0x7f, 0x01, 0x01}, // T
{0x3f, 0x40, 0x40, 0x40, 0x3f}, // U
{0x1f, 0x20, 0x40, 0x20, 0x1f}, // V
{0x3f, 0x40, 0x38, 0x40, 0x3f}, // W
{0x63, 0x14, 0x08, 0x14, 0x63}, // X
{0x07, 0x08, 0x70, 0x08, 0x07}, // Y
{0x61, 0x51, 0x49, 0x45, 0x43}, // Z
{0x00, 0x00, 0x00, 0x00, 0x00}, // space
{0x10, 0x18, 0x1c, 0x18, 0x10}, // new up arrow
{0x04, 0x0c, 0x1c, 0x0c, 0x04}, // new down arrow
{0x08, 0x08, 0x08, 0x08, 0x08}, // dash / maintain
{0x08, 0x08, 0x3E, 0x08, 0x08}, // plus
{0x00, 0x60, 0x60, 0x00, 0x00}, // full stop
{0x26, 0x16, 0x08, 0x34, 0x32}, // %
{0x24, 0x2a, 0xff, 0x2a, 0x12}// $
const int stockQty = 17; // this is the amount of different stock values to be contained, *!* ONE indexed *!*
const int stockStepQty = 5; // *!* ONE indexed *!*
int stockStep = 0;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(ledTotal + 1, stripPin, NEO_RGB + NEO_KHZ800);
WiFi.mode(WIFI_STA);
WiFi.disconnect(); //Disconnect and reconnect to the Wifi you set
WiFi.begin(ssid, password);
Serial.println("Connected to the WiFi network"); //Display feedback on the serial monitor
if (WiFi.status() != WL_CONNECTED) //In case the Wifi connexion is lost
WiFi.disconnect();
Serial.println("Reconnecting to WiFi..");
delay(10000);
strip.begin();
strip.show();
void stock_AR() {
int httpCode = http.GET(); //Check feedback if there's a response
if (httpCode > 0)
if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY)
Data_Raw = http.getString(); //Here we store the raw data string
Data_Raw_1 = Data_Raw;
To_remove = Data_Raw_1.indexOf(">"); //I look for the position of this symbol ">"
Data_Raw_1.remove(0, To_remove + 1); //I remove it and everything that's before
To_remove = Data_Raw_1.indexOf("<"); //I look for the position of this symbol ">"
Data_Raw_1.remove(To_remove, Data_Raw_1.length());
Amount = Data_Raw_1;
Serial.print("C: "); //I choosed to display it on the serial monitor to help you debug
Serial.println(Amount);
Data_Raw_2 = Data_Raw;
To_remove = Data_Raw_2.indexOf(">");
Data_Raw_2.remove(0, To_remove + 1);
To_remove = Data_Raw_2.indexOf("</td>");
Data_Raw_2.remove(0, To_remove + 5);
Data_Raw_2.remove(To_remove, Data_Raw_2.length());
Increase = Data_Raw_2;
Serial.print("D: ");
Serial.println(Increase);
Data_Raw_3 = Data_Raw;
To_remove = Data_Raw_3.indexOf("</td>");
Data_Raw_3.remove(0, To_remove + 5);
To_remove = Data_Raw_3.indexOf(">");
Data_Raw_3.remove(0, To_remove + 1);
To_remove = Data_Raw_3.indexOf("<");
Data_Raw_3.remove(To_remove, Data_Raw_3.length());
Ratio = Data_Raw_3;
Serial.print("R: ");
Serial.println(Ratio);
else //If we can't get data
Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
String titil;
String inputString;
stock_AR();
titil = "AR";
displayled();
char b[10];
char c[10];
void displayled() {
strcpy(b, Increase.c_str());
strcpy(c, Amount.c_str());
if ((b[0] == '-') && (c[0] == '$')) {
inputString = (titil + " " + Amount + "|" + Increase + " " + "|" + Ratio + " ");
else if ((b[0] == '-') && (c[0] != '$')) {
inputString = (titil + " " + "$" + Amount + " " + "|" + Increase + " " + "|" + Ratio + " ");
else if ((b[0] != '-') && (c[0] == '$')) {
inputString = (titil + " " + Amount + "^" + "+" + Increase + " " + "^" + "+" + Ratio + " ");
else if ((b[0] != '-') && (c[0] != '$')) {
inputString = (titil + " " + "$" + Amount + " " + "^" + "+" + Increase + " " + "^" + "+" + Ratio + " ");
for (int i = 0; i < inputString.length(); i++) {
char currentChar = inputString[i];
int currentCol, colorMode;// = int(colString[i]) - 48; // minus 48 because int("0") will return the ascii value of char '0' (48)
if ((currentChar >= 'A') && (currentChar <= 'Z')) {
currentCol = 0;
} /*else if ((currentChar == '+') || (currentChar == '-')) {
currentCol = colorMode;
} *//*else if((currentChar >= '0') && (currentChar <= '9') ||(currentChar == '%')){
colorMode = 3;
}*/else if ((currentChar == '^') || (currentChar >= '0') && (currentChar <= '9') && (currentChar == '%')) {
colorMode = 2;
} else if ((currentChar == '|') || (currentChar >= '0') && (currentChar <= '9') && (currentChar == '%')) {
colorMode = 1;
else if ((currentChar == '$') || (currentChar >= '0') && (currentChar <= '9') && (currentChar == '%')) {
colorMode = 4;
int indexValue;
if ((currentChar >= '0') && (currentChar <= '9')) indexValue = currentChar - 48; // 0-9
else if ((currentChar >= 'A') && (currentChar <= 'Z')) indexValue = currentChar - 55; // upper case
//else if ((currentChar >= 'a') && (currentChar <= 'z')) indexValue = currentChar - 61; // lower case , check that these are in the right place / the offset is correct, as i may have put the array chunk back in the wrong place!!
else if ((currentChar == ' ')) indexValue = 36; // space, was 62 when lower case chars
else if ((currentChar == '^')) indexValue = 37; // up arrow, was 63 when lower case chars
else if ((currentChar == '|')) indexValue = 38; // down arrow, was 64 when lower case chars
else if ((currentChar == '%')) indexValue = 42;
// else if ((currentChar == '<')) indexValue = 39; // left arrow, was 65 when lower case chars
// else if ((currentChar == '>')) indexValue = 40; // right arrow, was 66 when lower case chars
else if ((currentChar == '-')) indexValue = 39; // dash / maintain, was 67 when lower case chars, 41 with l/r arrows
else if ((currentChar == '+')) indexValue = 40; // plus
else if ((currentChar == '.')) indexValue = 41; // full stop
else if ((currentChar == '$')) indexValue = 43; // full stop
for (int x = 0; x < charWidth; x++) {
if (currentStatus == 0) currentStatus = 1;
else if (currentStatus == 1) currentStatus = 0;
setStatusIndicator(currentStatus);
nudgeColumns(displayLetters[indexValue][x], currentCol); // inputCols[i]); // strip.Color(0,0,255));
displayUpdate(0);
delay(50);
nudgeColumns(0, 0); // - 1 might break things here? or make things go white due to the lookup default being white
displayUpdate(0);
delay(50); // this will be 200 as per the rest once confirmed that the double jump issue is done!
int getIntLength(int value) {
// Function created by "zed_0xff" at: https://stackoverflow.com/a/3068412/7905386
int l = !value;
while (value) {
l++;
value /= 10;
return l;
int getMappedPixel(int columnID, int rowID) {
int z;
z = columnSize - columnID;
if (columnID % 2) z++;
z = z * (rowSize + 1);
if (columnID % 2) z = z - rowID - 1;
else z = z + rowID;
if (z >= 256) z++;
return z;
void setMappedColor(int columnID, int rowID, long pixelColor) {
int mappedPixel = getMappedPixel(columnID, rowID);
if (mappedPixel < ledTotal) {
strip.setPixelColor(mappedPixel, pixelColor);
else {
mappedPixel = mappedPixel - ledTotal;
void colorAll(long color) {
for (int i = 0; i <= rowSize; i++) {
for (int j = 0; j <= columnSize; j++) {
setMappedColor(j, i, color);
void convertToBits(byte inputValue, int outputArray[]) {
if (inputValue & 0x80) outputArray[0] = 1; // not used?
if (inputValue & 0x40) outputArray[0] = 1;
if (inputValue & 0x20) outputArray[1] = 1;
if (inputValue & 0x10) outputArray[2] = 1;
if (inputValue & 0x08) outputArray[3] = 1;
if (inputValue & 0x04) outputArray[4] = 1;
if (inputValue & 0x02) outputArray[5] = 1;
if (inputValue & 0x01) outputArray[6] = 1;
void displayUpdate(long backColor) {
colorAll(backColor);
for (int i = 0; i <= columnSize; i++) {
int columnData[rowSize + 1] = {0};
convertToBits(displayOutput[i], columnData);
for (int j = 0; j <= rowSize; j++) {
if (columnData[rowSize - j] == 1) setMappedColor(i, j, colorLookup(displayColors[i])); // was displayColors[i][j] before memory save
strip.show();
//stripB.show();
void nudgeColumns(byte newData, byte newColor) {
for (int i = 0; i < columnSize; i++) {
displayOutput[i] = displayOutput[i + 1];
displayColors[i] = displayColors[i + 1];
displayOutput[columnSize] = newData;
if (newColor >= 0) { // created for memory save
for (int k = 0; k <= rowSize; k++) {
displayColors[columnSize] = newColor;
long colorLookup(int inputColor) {
long outputColor = 0;
switch (inputColor) {
case 0:
outputColor = strip.Color(255, 255, 255); // white
case 1:
outputColor = strip.Color(255, 0, 0); // red
case 2:
outputColor = strip.Color(0, 255, 0); // green
case 3:
outputColor = strip.Color(0, 0, 255); // blue
case 4:
outputColor = strip.Color(255, 255, 0); // yellow/amber
case 5:
outputColor = strip.Color(0, 255, 255); // cyan
case 6:
outputColor = strip.Color(255, 0, 255); // magenta
default:
return outputColor;
void setStatusIndicator(byte inputStatus) {
if (inputStatus == 0) {
digitalWrite(13, LOW);
digitalWrite(13, HIGH);
[/code]
