It's not as bad as it first looks. You are soldering gold to gold, and you only need to do about six. I sharpened the tip of my iron but I'm not sure it was necessary.
A possible problem is the breakout board you linked to might not be fully suitable for your BT device as different pins are used for the LED depending on if you have a master or slave device and master also needs an extra pin to drop device into command mode.
You can solder to pcb pins but it's fiddly and not very portable.
Riva:
Thanks for the pic!!!!
May I know if you solder the header pins to the BT device or you simply bend the pins to "touch" on the connecting surface to the BT device?
I was thinking if there is any kind of holder to the BT device so that the setup can be temporary.
arduinocom:
I have bent the pins to touch and then soldered them. I only bent the pins needed (8 in this case) and left the rest free.
In hind sight I should have soldered the headers to a bit of stripboard first and then mount the BT module as this would make the whole thing more robust and stable. I'm dreading trying to remove the setup from the breadboard as I may damage the module.
arduinocom:
No. You have to swallow deep and solder it. As I said, it's not so hard to do. Having youth, or a good magnifier, might be more important than a sharp bit on the iron. Check the data sheet. One thing that can happen is that you solder it for an HC-06 when the module is actually an HC-05. This means the LED doesn't work until you solder the right contacts. I haven't bothered and live without it. Indeed I think it makes more sense not to have the LED.
Nick_Pyner:
You have to be a little careful when soldering those side-on pads, as too much heat
and they'll fall right off, and the thin traces will break, and they're toast. That's what
happened to my RFM12 transceivers, which have similar mounting pads, although I did
manage to scrape the broken traces clean and dab with solder under a magnifying
glass.
