Hi, I am new to the Arduino (just about to buy one plus an expansion sheild) and it seems that I will need 'buckled connectors' however I cannot seem to find a supplier (I have already tried Ebay ) Iwould appreciate any information anyone could give as to a possible supplier.
Is just me that has never heard of buckled cables ? There is screwy spacing on pins 8 - Aref, but the expansion shield will take care of that, care to elaborate on what you're going to do with the arduino ?
Not screwy, it's the term used by the chinese vendors that sell sensors using locking 3 and 4 pin connectors to their Arduino connector interface shield. Seeeduino sells some I think:
Lefty
Now I'm really confused, I think I'll stick to bending socket pins before I solder them to the bottom of the strip board.......
Well let me see if I can help the OP with references. He can correct me if I misinterruted his question.
Several asian vendors sell a connecting shield for a series of electronic components and sensors they call bricks. This is the shield part and notice the use of 3 pin snap connectors for the analog inputs and a 4 pin connector for the I2C/serial connetion:
A typical brick component are like this:
or this:
I think they usually supply a buckled connector when they sell you a brick device, but if needed one can buy the connectored cable as seperate items as shown towards the bottom of this page:
The term buckle, to me does seem to be unique to these products and it's probably a translation thing, but it's not that far a leap to accept.
Don't forget to buckle up for safety.
Lefty
Hahaha, yeah, that might be a Chinglish invention or maybe translated from English to Japaness then Chinese and back to English. According to page 79 on Jameco's catelog, it is called keyed shrouded headers and connectors. Parts 152734 and 152741.
Do we know what the actual connector is called? make? model number?
Is it some sort of latching variety of JST? Is it one of the standard pin spacings? 0.1"? 1mm? 1.5mm? 2mm?I was hoping that if Jim could identify what expansion shield board he is asking about,
we could trace the connector type back from there.
They are .1" pin spacing. They have a plastic locking lever that snaps into the socket and locks automatically as you press in the cable, but you have to manually press down on the lever to release and pull out the cable.
Not sure if there is a industrial name/type for these. It may be something unique to China for now?
Lefty
As far as I'm aware (and a year ago I wasn't), the buckled cable or connector is basically like the audio connector from an internal CD drive to a muthaboard. It's that sort of connector (I think), and the “buckle” terminology seems to be the little clippy pressy-inny bit that locks it in place.
Those do look as far as I can tell exactly the same as the 4 pin buckle connector I'm talking about. However I don't see a Jameco listing for the more common and often used 3 pin buckle connector.
Lefty
I agree, and I'm sure one could just cut down a female .1" header to 3 or 4 pin size and it would mate up fine, short the preesy-inny locky thingee.
Lefty
emartee has them
It would help if the OP came back in here and clarified matters.
As far as Seeedstudio goes, I know the connectors they use are compatible (cheap clones of!) Tyco AMPMODU MTE 103956 (tin) and 103957 (gold) series latching polarized connectors, available from Digikey: http://search.digikey.com/scripts/DkSearch/dksus.dll?vendor=0&keywords=103956
They are not horribly expensive. Most cheap crimping tools won't work with the preloaded housing though, so you'll need to do some disassembly.
Thanks for the fast response guys !
Sorry I didn't give enough information, they are 3 wire and as you surmised the cables are the 'Chinese ' ones ( most of the shields on EBAY seem to use them) see
http://cgi.ebay.co.uk/Arduino-Sensor-Shield-V4-digital-analog-module-servos-/370386073399?pt=LH_DefaultDomain_0&hash=item563cbaf737#ht_3604wt_1026
The only supplier I can find is in america , I think the postage / wait would kill it ! this link shows the cable
Looks like a three connector version of this (which is four connector):
http://www.maplin.co.uk/Module.aspx?ModuleNo=28726 (ZV00A)
Thanks, got it sorted now, realised that the supplier was in fact from china emartee as advised, ... placed my order for a Roboduino as well so now its time to start to learn ' processing' whilst waiting for my delivery
Jim
