Help whith code html...
Hi, anyone can tell me how pass this html code from the Arduino to the micro sd card of ethernet shield?
cliente.print("HORA ATUAL: ");
if (hour<10)
cliente.print("0");
cliente.print(hour);
cliente.print(":");
if (minute<10)
cliente.print("0");
cliente.print(minute);
cliente.print(":");
if (Second<10)
cliente.print("0");
cliente.print(Second);
cliente.println("
Thanks... :wink:
That isn't "html code". That is code that sends data to a client.
The code to send the same data to an SD card looks exactly the same, except that client is replaced by the file instance, once you've opened a file.
Take out the SD card and connect it to a computer. Create a file on the computer and write it to the SD card :slight_smile:
When you want to write the time to a file, you can use the same 'print' and 'println'.
See the examples for the SD library.
