#define CUSTOM_SETTINGS
#define INCLUDE_TEXT_TO_SPEECH_SHIELD
#define INCLUDE_VOICE_RECOGNIZER_SHIELD
#define INCLUDE_CLOCK_SHIELD
/* Include 1Sheeld library. */
#include <OneSheeld.h>
#define loadPin 13
#define battery 12
#define mic 8
#define led 7
#define voltimeter A0
#define bright A1
#define echoPin 11
#define trigPin 10
#define tempoMaximoDeUmaPalma 150 //milisegundos
#define tempoMaximoEntrePalmas 500 //milisegundos
boolean load = false;
byte hour, minute, second, day, month, year;
byte contaPalmas = 0;
unsigned long tempoEspera = 0;
unsigned long tempoEsperaEntrePalmas = 0;
float Vo = 0.0, Vi = 0.0;
float value_aux = 0, value = 0;
//Valores dos Resistores//
float R1 = 1000000.0; //Resistência R1 (992K) -see text!
float R2 = 300000.0; //Resistência R2 (168K) - see text!
/* A command which will be compared. */
const char ONCommand=“ligar”;
const char OFFCommand=“desligar”;
const char timeCommand=“em que tempo estamos”;
/* A name for the LED on pin 13. */
const char energyCommand=“energia”;
const char distanceCommand=“teste”;
void palmas();
void relogio();
void voltimetro();
void aproximacao();
/* Start communication. */
OneSheeld.begin();
Clock.queryDateAndTime();
pinMode(loadPin,OUTPUT);
pinMode(battery,OUTPUT);
pinMode(led,OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(mic, INPUT);
pinMode(voltimeter,INPUT);
pinMode(bright,INPUT);
pinMode(echoPin, INPUT);
digitalWrite(battery,HIGH);
digitalWrite(loadPin,LOW);
digitalWrite(led,LOW);
palmas();
/* Always check if a new voice command received. */
if(VoiceRecognition.isNewCommandReceived())
/* Check if the voice command is the desired one. */
if(!strcmp(ONCommand,VoiceRecognition.getLastCommand()))
digitalWrite(battery,LOW);
delay(3500);
TextToSpeech.say(“gerador ativado”);
digitalWrite(loadPin,HIGH);
delay(300);
load = true;
delay(200);
else if(!strcmp(OFFCommand,VoiceRecognition.getLastCommand()))
delay(300);
TextToSpeech.say(“gerador desativado”);
delay(2000);
delay(200);
else if(!strcmp(energyCommand,VoiceRecognition.getLastCommand()))
voltimetro();
else if(!strcmp(timeCommand,VoiceRecognition.getLastCommand()))
relogio();
else if(!strcmp(distanceCommand,VoiceRecognition.getLastCommand()))
aproximacao();
void relogio()
String hora=String( Clock.getHours());
TextToSpeech.say(“agora”);
OneSheeld.delay(1000);
TextToSpeech.say(hora);
TextToSpeech.say(“horas”);
String minutos=String(Clock.getMinutes());
TextToSpeech.say(minutos);
OneSheeld.delay(1500);
TextToSpeech.say(“minutos”);
String segundos=String(second = Clock.getSeconds());
TextToSpeech.say(segundos);
TextToSpeech.say(“segundos”);
TextToSpeech.say(“hoje é”);
TextToSpeech.say(“dia”);
String dia=String(Clock.getDay());
TextToSpeech.say(dia);
TextToSpeech.say(“do mês”);
String mes=String(Clock.getMonth());
TextToSpeech.say(mes);
TextToSpeech.say(“do ano”);
String ano=String(Clock.getYear());
TextToSpeech.say(ano);
OneSheeld.delay(3000);
delay(200);
void voltimetro()
for(int i=60;i>0;i–){
value_aux = analogRead(voltimeter);
value += pow(value_aux,2);
value = sqrt(value/60);
Vo = (value * 5.0) / 1023.0;
Vi = Vo / (R2/(R1+R2))-0.48;
if (Vi<0.09) {Vi=0.0;} //Filtrando medições errôneas!
String stringone=String(Vi);
String stringtoo=String(Vo);
TextToSpeech.say(stringone);
delay(3000);
TextToSpeech.say(“volts”);
int porcentagem =(int)Vi;
int valor =map(porcentagem,11,13,0,100);
String string=String(valor);
TextToSpeech.say(string);
TextToSpeech.say(“por cento”);
delay(200);
void palmas()
boolean sensorSom = digitalRead(mic);
//se o sensor detectou palmas
if (sensorSom == LOW) {
//espera um tempo para nao detectar a mesma palma mais de uma vez
if (tempoEspera == 0)
tempoEspera = tempoEsperaEntrePalmas = millis();
contaPalmas++;
else if ((millis() - tempoEspera) >= tempoMaximoDeUmaPalma)
tempoEspera = 0;
//caso exceda o tempo maximo entre palmas, zera o contador de palmas
if ( (contaPalmas != 0) && ((millis() - tempoEsperaEntrePalmas) > 500) )
switch (contaPalmas) {
case 2:
VoiceRecognition.start();
delay(200);
digitalWrite(led,HIGH);
contaPalmas = 0;
void aproximacao()
digitalWrite(trigPin, HIGH);
delay(10);
digitalWrite(trigPin, LOW);
long duration = pulseIn(echoPin,HIGH);
long distancia = duration /29 / 2 ;
if(distancia<40){
delay(200);
TextToSpeech.say(“alerta de proximidade”);
TextToSpeech.say(“recue imediatamente”);
delay(4000);
delay(200);
