Help! Why does this one only once?
I am working on this robotics project and am working on making it more autonomous. I have some simple code for continuously rotating a servo to 180 deg and then to 0 deg. This very simple code is only running once then stopping. Why might that be? Please help.
#include <Servo.h>
Servo srvB;
Servo srv2;
Servo srvM;
boolean magSt = true;
srvB.attach(10);
srvM.attach(9);
srv2.attach(6);
if (magSt){
srvM.write(180);
else{
srvM.write(0);
magSt = true;
delay(1111);
magSt = false;
delay(1111);
Typo. RUN only once.
Think about what is happening here.
magSt = true;
delay(1111);
magSt = false;
delay(1111);
Update: I used millis() timing and now it works as intended. Strange. Anyone have any ideas as to why that is?
Oh, so the delays prevent the if condition from doing what it's supposed to?
Ok. So my goal now is that when the button is pressed and released it rotates the motor to 180 deg or 0 deg. So will this code work?
#include <Servo.h>
Servo srvB;
Servo srv2;
Servo srvM;
boolean bsn = false;
int button = 2;
unsigned long onTime;
unsigned long offTime;
unsigned long previousMillis=0;
int interval = onTime;
srvB.attach(10);
srvM.attach(9);
srv2.attach(6);
if (magSt){
srvM.write(180);
else{
srvM.write(0);
if (digitalRead(button) == LOW){
bsn = true;
else{
  bsn = false;
if (bsn){
if (digitalRead(button) == HIGH){
magSt != magSt;
bsn = false;
Ok. This code seems to also not work. Why is that?
bsn = true;
if (bsn && digitalRead(button) == HIGH){
magSt != magSt;
bsn = false;
Yeah, sorry. It just doesn't change between states like it's supposed to - it stays on regardless of what I do.
Thanks. I am just making some careless mistakes because I am kind of tired.
Instead of this;
bsn = true;
magSt != magSt;
bsn = false;
where you read the input at every stage you need it through the code.
You should be reading ALL your digital inputs at the start of the code, storing them in variables, ad use the stored variable in any computation.
So
bool buttonVal;
buttonVal=digitalRead(button);
if (buttonVal == LOW)
bsn = true;
if (bsn && buttonVal == HIGH)
magSt = !magSt;
bsn = false;
That way if you have many inputs, you take a snapshot of the inputs and apply your code.
Tom.... :slight_smile:
Ok. So now that I am a lot less tired I have been able to make some real progress. So I have a servo controlling a 90lbs magswitch(https://www.kjmagnetics.com/proddetail.asp?prod=MJ-95) that I will soon attach to a robotic arm. The problem is, often magnetized items stick to the magswitch when it is off. I often have to shake it. So, I am trying to get it so that the arm will shake a little when you hold the button for a certain duration. For testing purposes, I am having it rotate to random degs.
I am having some problems with the for loop involving z and the boolean "longPress". What happens is it works as it's supposed to in the beginning. However, once I hold it down for 1.2+ secs, it CONTINUOUSLY rotates to random deg until I stop holding it. I have tried various things and it is still doing this. What am I not seeing?
#include <Servo.h>
Servo srvB; //baser servo of arm
Servo srv2; //second servo arm
Servo srvM; //servo with magswitch(R) attached
boolean bsn = false; // button state NOW
boolean pbs = false;//PREVIOUS button state
int button = 2; //button pin
boolean magSt = false; //magswitch(R) on or off
boolean longPress = false; //when pressed for a long time
int i =0; //for repeating certain code only once
int z = 0;//^^^
unsigned long onTime; //for timing stuff with indep on/off times
unsigned long offTime;// ^^^
int interval = onTime;//^^^
unsigned long pMil=0; //previous millis recorded
srvB.attach(10);
srvM.attach(9);
srv2.attach(6);
pinMode(button, INPUT_PULLUP); }
bsn = !digitalRead(button);
unsigned long cMil = millis();
if (magSt){
srvM.write(180);
digitalWrite(LED_BUILTIN, HIGH);
else{
srvM.write(0);
digitalWrite(LED_BUILTIN, LOW);
if (bsn == true)  {
z = 0;
for(i; i < 1; i++) {
pMil = millis();
if(cMil - pMil < 1200){
longPress = false;
pbs = true;
else {
longPress =true;
pbs = false;
else{
i = 0;
if (pbs && !bsn){
magSt = !magSt;
pbs = bsn;
if(longPress){
for(z; z < 1; z++){
srvB.write(random(0, 180));
srv2.write(random(0, 180));
