Help why wont this cod work
can some one please help with the attached cod as it is driving me mad
after sorting out all the bugs and getting to upload to the uno the stepper motor will not run?
but it i remove the if else part the motor runs fine?
thanks Paul
if else.ino (904 Bytes)
Please post your code, in code tags.
Hello P1A2
Welcome to the worldbest forum.
We need some additional information.
Post your sketch, well formated, with well-tempered comments and in so called code tags "< code >" and schematic to see how we can help.
Welcome to the forum
Please post your code here, using < CODE/ > tags when you do
how do i do that?
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Do you want live notifications when people reply to your posts? Enable Notifications​
Custom dashboards, smartphone remote control, data sharing between boards, remote uploads. Get them (for free) using your forum account!
Using Arduino
Programming Questions
Apr 8
6m
P1A2
2
7mpost #1
thanks
t code for the forum`
[if else.ino|attachment](upload://mGUxpxx4f0PpRarEqtFrbbc3OVs.ino) (904 Bytes)
In the IDE, right click and select Copy for Forum. In a new post paste what the IDE has put on the clipboard and it will include the < CODE/ > tags for you. Save the new post
type or paste code here
thanks i think i've got it
Nope.
Like this
Your code here
int switchpin2 = 11;
  digitalRead(switchpin2);  //read the state of switchpin2 and ignore it
  if (switchpin2 > HIGH)  //the value of switchpin2 will still be 11
Note my added comments
Test the value returned by digitalRead(switchpin2) not the value of switchpin2 itself which will not have changed
[quote="SemperIdem, post:10, topic:1112700"]
Like this
int dirpin = 4;
int pulsepin = 5;
int enablepin = 3;
int switchpin1 = 10;
int clockwise = 0;
int counterclockwise = 1;
void setup (){
pinMode(dirpin,OUTPUT);
pinMode(pulsepin, OUTPUT);
pinMode(enablepin, OUTPUT);
pinMode(switchpin1, INPUT);
pinMode(switchpin2, INPUT);
spin(counterclockwise.3.200);
void loop(){
void spin (int direction, int dly, int steps){
digitalRead(switchpin1){
if (switchpin1>HIGH);
digitalWrite(enablepin,HIGH);
}else if (switchpin1>LOW){
(digitalWritw(enablepin,LOW));
if (switchpin2>HIGH){
(digitalWrite(dirpin,HIGH));
} else (switckpin2>LOW);
digitalWrite(dirpin,LOW);
for (int step = 1,steps< steps +1.steps++);
digitalWrite(pulsepin,LOW);
delay(1);
digitalWrite(pulsepin,HIGH);
delay(dly);
digitalWrite(enablepin,LOW);
}Use code tags to format code for the forum
11 (switchPin) is always greater than 1(HIGH)
Lose the semicolon.
Didn't the compiler complain?
Again, lose the semicolon.
And the commas.
click the <CODE/> icon and post the code in the highlighted area
int dirpin = 4;
int pulsepin = 5;
int enablepin = 3;
int clockwise = 0;
void setup ()
    pinMode (dirpin,OUTPUT);
    pinMode (pulsepin, OUTPUT);
    pinMode (enablepin, OUTPUT);
    pinMode (switchpin1, INPUT);
    pinMode (switchpin2, INPUT);
    spin (counterclockwise.3.200);
void loop (){
    digitalRead (switchpin1) {
            digitalWrite (enablepin,HIGH);
    else if (switchpin1>LOW) {
        (digitalWritw (enablepin,LOW));
        digitalRead (switchpin2);
        if (switchpin2>HIGH) {
            (digitalWrite (dirpin,HIGH));
            (switckpin2>LOW);
        digitalWrite (dirpin,LOW);
    digitalWrite (pulsepin,LOW);
    delay (1);
    digitalWrite (pulsepin,HIGH);
    delay (dly);
    digitalWrite (enablepin,LOW);
  • looks like spin would get executed once in setup()
  • not sure what the following intends to do. looks like the brace, "{", shoudl be after the if, replacing the semicolon, ";"
  • should this be an else if?
            (switckpin2>LOW);
  • is this for loop missing braces? the semicolon is the body of the loop
what is it intended to do?
