I'm currently working on a project involving the 16-Bit LED Nixie tube Driver and Keyboard Control Chip (CH453) and I'm trying to integrate it with an Arduino. However, I'm running into some difficulties and would greatly appreciate any help or guidance.
Welcome to the forum!
You will get faster and better help if you describe your problem in detail and post your code (if any) as requested by the forum guidelines. Read the forum guidelines to see how to properly ask a question and some good information on making a good post.
After connect the 16 digits to ch453 i did scan using Arduino code
There i found 24 addresses what is that means
Do you have any code?? If you have that could you share with me
I think they did not implement a device address. Similar to the TM1637.
In this case you start the communication with the command instead of the device address. Now it makes sense that you find many devices when you scan the i2c.
There is a library for the CH423. Maybe this can be a starting point for this chip:
