Help with 3.5" TFT
I purchased a 3.5" TFT from baggood but this is the only code that I can use for it to operate.
All examples using ADAfruit GFX and TFT libraries result in a blank screen. Why would this be?
//Technical support:goodtft@163.com
// Breakout/Arduino UNO pin usage:
// LCD Data Bit :   7   6   5   4   3   2   1   0
// Uno dig. pin :   7   6   5   4   3   2   9   8
// Uno port/pin : PD7 PD6 PD5 PD4 PD3 PD2 PB1 PB0
// Mega dig. pin:  29  28  27  26  25  24  23  22
#define LCD_RD   A0
#define LCD_WR   A1
#define LCD_RS   A2
#define LCD_CS   A3
#define LCD_REST A4
#define WR_MASK B00000010
#define RS_MASK B00000100
void Lcd_Writ_Bus(unsigned char d)
  PORTD = (PORTD & B00000011) | ((d) & B11111100);
  PORTB = (PORTB & B11111100) | ((d) & B00000011);
  PORTC &= ~WR_MASK;
  PORTC|=  WR_MASK;
void Lcd_Write_Com(unsigned char VH)
   PORTC &= ~RS_MASK;
  Lcd_Writ_Bus(VH);
void Lcd_Write_Data(unsigned char VH)
  PORTC |= RS_MASK;
  Lcd_Writ_Bus(VH);
void Lcd_Write_Com_Data(unsigned char com,unsigned char dat)
  Lcd_Write_Com(com);
  Lcd_Write_Data(dat);
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
        Lcd_Write_Com(0x2a);
	Lcd_Write_Data(x1>>8);
	Lcd_Write_Data(x1);
	Lcd_Write_Data(x2>>8);
	Lcd_Write_Data(x2);
        Lcd_Write_Com(0x2b);
	Lcd_Write_Data(y1>>8);
	Lcd_Write_Data(y1);
	Lcd_Write_Data(y2>>8);
	Lcd_Write_Data(y2);
	Lcd_Write_Com(0x2c);
void Lcd_Init(void)
  digitalWrite(LCD_REST,HIGH);
  delay(5);
  digitalWrite(LCD_REST,LOW);
  delay(15);
  delay(15);
  digitalWrite(LCD_CS,HIGH);
  digitalWrite(LCD_WR,HIGH);
  digitalWrite(LCD_CS,LOW);  //CS
Lcd_Write_Com(0x11);
  delay(20);
  Lcd_Write_Com(0xD0);
  Lcd_Write_Data(0x07);
  Lcd_Write_Data(0x42);
  Lcd_Write_Data(0x18);
  Lcd_Write_Com(0xD1);
  Lcd_Write_Data(0x00);
  Lcd_Write_Data(0x07);//07
  Lcd_Write_Data(0x10);
  Lcd_Write_Com(0xD2);
  Lcd_Write_Data(0x01);
  Lcd_Write_Data(0x02);
  Lcd_Write_Com(0xC0);
  Lcd_Write_Data(0x3B);
  Lcd_Write_Data(0x11);
  Lcd_Write_Com(0xC5);
  Lcd_Write_Data(0x03);
  Lcd_Write_Com(0x36);
  Lcd_Write_Data(0x0A);
  Lcd_Write_Com(0x3A);
  Lcd_Write_Data(0x55);
  Lcd_Write_Com(0x2A);
  Lcd_Write_Data(0x3F);
  Lcd_Write_Com(0x2B);
  Lcd_Write_Data(0xE0);
  delay(120);
  Lcd_Write_Com(0x29);
  Lcd_Write_Com(0x002c);
void H_line(unsigned int x, unsigned int y, unsigned int l, unsigned int c)
  unsigned int i,j;
  Lcd_Write_Com(0x02c); //write_memory_start
  digitalWrite(LCD_RS,HIGH);
  l=l+x;
  Address_set(x,y,l,y);
  j=l*2;
  for(i=1;i<=j;i++)
    Lcd_Write_Data(c);
void V_line(unsigned int x, unsigned int y, unsigned int l, unsigned int c)
  unsigned int i,j;
  l=l+y;
  Address_set(x,y,x,l);
  j=l*2;
  for(i=1;i<=j;i++)
    Lcd_Write_Data(c);
void Rect(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned int c)
  H_line(x  , y  , w, c);
  H_line(x  , y+h, w, c);
  V_line(x  , y  , h, c);
  V_line(x+w, y  , h, c);
void Rectf(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned int c)
  unsigned int i;
  for(i=0;i<h;i++)
    H_line(x  , y+i, w, c);
int RGB(int r,int g,int b)
{return r << 16 | g << 8 | b;
void LCD_Clear(unsigned int j)
  unsigned int i,m;
 Address_set(0,0,320,480);
  //Lcd_Write_Com(0x02c); //write_memory_start
  //digitalWrite(LCD_RS,HIGH);
  for(i=0;i<320;i++)
    for(m=0;m<480;m++)
      Lcd_Write_Data(j>>8);
      Lcd_Write_Data(j);
  for(int p=0;p<10;p++)
    pinMode(p,OUTPUT);
  pinMode(A0,OUTPUT);
  pinMode(A1,OUTPUT);
  pinMode(A2,OUTPUT);
  pinMode(A3,OUTPUT);
  pinMode(A4,OUTPUT);
  digitalWrite(A0, HIGH);
  digitalWrite(A1, HIGH);
  digitalWrite(A2, HIGH);
  digitalWrite(A3, HIGH);
  digitalWrite(A4, HIGH);
  Lcd_Init();
 //LCD_Clear(0xf800);
   LCD_Clear(0xf800);
   LCD_Clear(0x07E0);
   LCD_Clear(0x001F);
  for(int i=0;i<1000;i++)
    Rect(random(300),random(300),random(300),random(300),random(65535)); // rectangle at x, y, with, hight, color
//  LCD_Clear(0xf800);
I got the same software with a 3.5" display (controller: ILI9481) which looks like this:
http://shop.boxtec.ch/tft-lcd-shield-for-arduino-unomega-ili9481-p-42762.html
That example software worked because it directly addresses the controller, using some crude block graphics methods. The other, more complex ones did not.
I found a similar set of examples on the site of another vendor which used the MCUFRIEND_kbv.h library and these worked.
The code in post #4 here http://forum.arduino.cc/index.php?topic=485391.0 worked for me.
See also this thread (latest entries) for similar issues: http://forum.arduino.cc/index.php?topic=366304.0
