Help with 433 Receiver code
I have a Transmitter sending just a 1-6 send("1");
And a receiver
SimpleReceive
This sketch displays text strings received using VirtualWire
Connect the Receiver data pin to Arduino pin 11
#include <VirtualWire.h>
byte message[VW_MAX_MESSAGE_LEN]; // a buffer to store the incoming messages
byte messageLength = VW_MAX_MESSAGE_LEN; // the size of the message
 Serial.println("Device is ready");
 // Initialize the IO and ISR
 vw_setup(2000); // Bits per sec
 vw_rx_start(); // Start the receiver
void readSensor(){
 if (vw_get_message(message, &messageLength)) // Non-blocking
  Serial.print("Received: ");
  for (int i = 0; i < messageLength; i++){
   Serial.write(message[i]);}
void loop(){
readSensor();
if (vw_get_message(message, &messageLength)  == 1){
 Serial.println("button: ONE");
else if (vw_get_message(message, &messageLength)  == 2){
 Serial.println("button: Two");
else if (vw_get_message(message, &messageLength)  == 3){
 Serial.println("button: Three");
else if (vw_get_message(message, &messageLength)  == 4){
 Serial.println("button: Four");
else if (vw_get_message(message, &messageLength)  == 5){
 Serial.println("button: Five");
else if (vw_get_message(message, &messageLength)  == 6){
 Serial.println("button: Six");
delay(2000);
Now I do get 1-6 with this part of the code in the monitor
but I only get
In the monitor. What do I have wrong?
I'm not sure what led you this,
The reason you always see button: One, is because vw_get_message(uint8_t* buf, uint8_t* len) returns TRUE or 1 if there is a message and 0 if there is not.
But I can tell you that you want to be checking message[0] instead of vw_get_message(message, &messageLength). You know your going to get a value between 1 - 6, so you can use case statements to show what button was pressed.
Wow I have no idea why I did not see it thanks!!
