Hi I’m Sam, new to the forum and fairly new to Arduino but enjoying what is able to be done with one!
I wonder if anyone could help though as I have searched the internet trying to find how you use the data received from a readymade 433mhz remote sending to the Arduino but all I can find is the code to listen not how to then use it.
My project consists of a 3 button remote that originally came with a receiver that controlled on, off and PWM dimming of a led strip but the receiver chip has stopped working so I am now trying to use a Arduino and a cheap Ebay 433mhz receiver to accomplish the same task, my problem is I thought after finding the code my remote outputs that it was as easy as using a “if” statement but it seems not and I can only find code and tutorials on how to listen to the signals not use them to control outputs.
If anyone could explain how I can use the data from my receiver I would be very grateful
This is the code I was trying to use, it receives and prints to serial fine but I guess I cant use if statements here?
#include <RemoteReceiver.h>
int led = 13;
// start the remote receiver using interrupt 0 (pin 2)
RemoteReceiver::start(0);
pinMode(led, OUTPUT);
int code = RemoteReceiver::getData();
//digitalWrite(led, HIGH);
if(RemoteReceiver::dataReady()){
Serial.print("Read: ");
Serial.println(RemoteReceiver::getData());
if (code == 11528308) {
if (code == 11528306) {
digitalWrite(led, LOW);
Thanks in advance
Sam
This won’t work, because “code” is declared integer and can have values only from -32768 to 32767.
For that line to work “code” must be declared long, and getdata() must also return a long.
Where did you get the RemoteReceiver library?
Do you know for sure that it will decode your remote?
Hi jremington, thanks for the reply!
I looked at several libraries online where people were using the same type of ebay remote as me so I just downloaded whichever they used and the remote switch was one of them but all the sketches I can find never show how to use the received transmitter input only to re transmit it somewhere else etc.
this is where I found that library:
I have also used others which all ouput the same codes from my remote anyway, I will attach 3 screenshots below of different sketches and outputs as I press each of the 3 remote buttons if that helps.
What im looking to have it do is use the RF input to control the outputs on a nano or attiny, I can figure out the pwm and function side of things with trial and error but I just couldn’t find online how you use the incoming RF signal when using a ready built transmitter.
also I opened up my transmitter and its running a ev1527 ic if that helps?
I am very new to arduino so any help you can give is much apriciated!
how do I see if the library function is declared long?
Thanks in advance
Sam
No, that library did not come from that link. There is no function named getData().
Try changing "int" to "long".
Thanks jremington!
It didn't work with the remotereceiver library but it works with the RCswitch one so I will use that for my project using the "long" variable
Time to go figure out the rest of my code now.
Many thanks for the help and I hope once I learn more about arduino I can help others too.
Sam
