Help with 74ACT299 shift register
I'm using a 74ACT299PC universal shift register to control 8 pins on common anode LEDs.
Spec sheet: 74ACT299PC pdf, 74ACT299PC Description, 74ACT299PC Datasheet, 74ACT299PC view ::: ALLDATASHEET :::
And here is what I wired up:
Digital Pin 5 = DS0 (dataPin)
Digital Pin 6 = CP (clockPin)
Digital Pin 7 = S0 (latch pin)
I think I'm close to understanding the way the code works to write the data to the shift register and then turn on the LEDs but everything I have tried so far doesn't work.
I was hoping someone could look at this and see if I have everything wired correctly, and if that is the case I know it's just a matter of figuring out the code.
Thanks in advance.
You might want to enable the outputs with the OE pin!
Hows that? Forgive my noobness.
The spec sheet says:
A HIGH signal on either OE1 or OE2 disables the 3-STATE buffers and puts the I/O pins in the high impedence state. In this condition the shift, hold, load and reset operations can still occur. The 3-STATE buffers are also disabled by HIGH signalson both S0 and S1 in preparation for a parallel load operation.
I don't quite know what the 3-STATE buffer is and how it plays into the operation of the shift register.
With the examples of the 74HC595 it's a bit straightforward as there are only 3 pins control the shift register.
But how would this be different? Are there different connections that I need to make or pins I need to toggle?
This is the code I am using. I'm just trying to get the very very very very basics of it to work and make sure I have it wired properly. I'll worry about byte arrays and everything else later. Right now I just want to prove that I can do it.
int latchPin = 7;
int clockPin = 6;
int dataPin = 5;
//set pins to output
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
digitalWrite(latchPin, LOW); //set latchPin low to allow data flow
digitalWrite(dataPin, LOW);
digitalWrite(clockPin, LOW); // for each bit in dataOut send out a bit
digitalWrite(dataPin, LOW); //sets dataPin to HIGH or LOW depending on pinState
digitalWrite(clockPin, HIGH); //write the data
digitalWrite(clockPin,LOW);
digitalWrite(dataPin, HIGH); //sets dataPin to HIGH or LOW depending on pinState
digitalWrite(latchPin, HIGH); //set latchPin to high to lock and send data
