hi im tinkering around with a 74HC595 chip and i was trying to figure out how to controll induvial leds. all the guides about these chips are just about understanding how it works and not how to program it. I understand how it shifts in data, but I am unable to creat a correct code to turn induvial leds on.
with the code below i was able to turn on led #1 , but when i was unable to turn any single one on…
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
//set pins to output so you can control the shift register
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
// count from 0 to 255 and display the number
// on the LEDs
for (int i = 0;i < 2; i++) {
// take the latchPin low so
// the LEDs don’t change while you’re sending in bits:
digitalWrite(latchPin, LOW);
// shift out the bits:
shiftOut(dataPin, clockPin,00000001, i);
//take the latch pin high so the LEDs will light up:
digitalWrite(latchPin, HIGH);
// pause before next value:
delay(1);
ok i think i get it now. using this code i was able to turn one leds and make them flash at different intervals.
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
// on the LEDs
for (int i = 0;i < 256; i++) {
shiftOut(dataPin,clockPin, MSBFIRST, B01000000);
shiftOut(dataPin,clockPin,MSBFIRST, B00000001);
delay(200);
digitalWrite(latchPin,LOW);
shiftOut(dataPin,clockPin,MSBFIRST,B00000100);
