help with 8x8 Matrix code
hello i was woundering if someone can help me modify this code to work with an 8x8 matrix.
 * Show animations on a DIMxDIM led matrix
 * Uses Timer1 library to
 * constantly run an interrupt routine
 * at a specified frequency. This
 * refreshes the display without the
 * main loop having to do anything.
#include <TimerOne.h>
//#define TESTMODE // continuously sequence thru the LED's
#define DIM 5 // x/y dimension - 5x5 matrix
#define DIM1 (DIM-1)
typedef byte Frame[DIM];
#include "frames.h"
byte row = 0;
byte *curFrame;
int curFrameIdx;
// col[xx] of leds - anodes
// these are the arduino pins assigned to each column
int cols[DIM] = {37,36,35,34,33};
// row[xx] of leds - cathodes
// these are the arduino pins assigned to each row
int rows[DIM] = {7,6,5,4,3};
Frame blankFrame =
{B00000,
 B00000,
 B00000,
 B00000,
 B00000};
// blank the screen
void clearLeds() {
  // blank screen
  curFrame = blankFrame;
// select a frame to display
// idx = 0 -> FRAMDECNT-1
void setFrame(int idx) {
  curFrame = Frames[idx];
// Interrupt routine
// each time display() is called, it turns off the previous row
// and turns on the next row
byte bitMask = B00000011;
void display() {
  digitalWrite(rows[row], HIGH);  // Turn whole previous row off
  if (bitMask == B00010000) {
    bitMask = B00000011;  // light the right 2 columns (pins 9,8)
    // increment row and wrap if necessary
    if (++row == DIM) {
      row = 0;
  else if (bitMask == B00000011) {
    bitMask = B00001100;  // light the middle 2 columns (pins 11,10)
  else { // bitMaskIdx == B00001100
    bitMask = B00010000;  // light the leftmost column (pin 12)
  // direct port manipulation.
  // PORTB is a pseudo variable for digital pins 8 to 13 The two high bits (6 & 7) map to the crystal pins and are not usable
  // the bottom 5 bits are our columns.  We don't want to change the other bits,
  // so we first mask the bits we ignore, and then set the bits we want to light
  PORTC &= B11100000;
  PORTC |= curFrame[row] & bitMask;
  digitalWrite(rows[row], LOW); // Turn whole row on at once (for equal lighting times)
  int i;
  // sets the pins as output
  for (i = 0; i < DIM; i++) {
    pinMode(cols[i], OUTPUT);
    pinMode(rows[i], OUTPUT);
  // set up cols and rows (set display to dark)
    digitalWrite(cols[i], LOW);
    digitalWrite(rows[i], HIGH);
  clearLeds();
#ifdef TESTMODE
  while (1) {
  for (i=0;i < DIM;i++) {
    digitalWrite(rows[i],LOW);
    for (int j=0;j < DIM;j++) {
      digitalWrite(cols[j],HIGH);
      delay(250);
      digitalWrite(cols[j],LOW);
    digitalWrite(rows[i],HIGH);
#else // !TESTMODE
  // interrupt interval in uSec
  // this determines how long to keep each row turned on
  // so if we have 5 rows, we redraw the whole screen
  // once every 5 rows * 3 cycles per row * 1000 usec = .015 sec -> 66.67Hz
  // if you perceive flickering you can decrease to 500 for a 133.33Hz rate
  Timer1.initialize(1000);
  Timer1.attachInterrupt(display); // ISR
  curFrameIdx = -1;
#endif // TESTMODE
  // increment the frame index and wrap if necessary
  if (++curFrameIdx == FRAMECNT) {
    curFrameIdx = 0;
  // select frame for display
  setFrame(curFrameIdx);
  delay(400); // wait time between frames in ms
Change the value of DIM to 8.
Anywhere there is an array of size 5, make it an array of size 8.
Anywhere there is a value that is 5 bits long, make it 8 bits.
Seeing as how that code uses direct port manipulation, you'll need to make sure that all the pins used are on the same port.
i tried changing DIM 8 but i may have been useing the wrong pins. i am using arduino mega. what pins are on what ports. thanks.
int cols[DIM] = {37,36,35,34,33}; <<<<----- add 3 more pins here
int rows[DIM] = {7,6,5,4,3}; <<<<----- add 3 more pins and here
i cant just add any pin. they have to be of the same port.
and i dont know what pins it is
The port-numbers of the atmega2560 controller can be found in the data-sheet,
http://www.atmel.com/dyn/resources/prod_documents/doc2549.pdf, page two shows a lay-out
of the chip with pin/port-numbers.
With the schematics it's possible to determine which ports are available on which pins http://arduino.cc/en/uploads/Main/arduino-mega2560-schematic.pdf.
Just had a look and have not worked with the 2560 yet, all pins of ports A, B, C, F, K and L seem available on arduinos headers, pins of other ports are available partly.
thanks for all the help. i have figured it out.
