Help with a basic "if" statement
I'm relativley new with Arduino and programming in general. I've Just been playing around with it for a few days and I can't seem to get this basic "if" statement to work. I am trying to use as a counter so that "if" the LED flashes 50 times, it will turn off for 5 seconds, then reset the counter. Here is the code I have:
int LED = 6;                    //Assigning pin 6 as "LED"
int FlashCount = 0;            //Flashcount setup
  pinMode (LED, OUTPUT);
  Serial.begin (9600);
  digitalWrite(LED, HIGH);            //LED on for 50 mills
 delay (50);
digitalWrite(LED, LOW);                //LED off for 50 mills
delay (50);
FlashCount = FlashCount + 1;          //Counter + 1
Serial.print ("Flash Count = ");
Serial.println (FlashCount);
if (FlashCount == 50);                 //Flascount = 50?
  digitalWrite(LED, LOW);            //Do this if so
  delay(5000);
  FlashCount == 0;                  //Resets the counter
The program seems to simply skip the "if" statement all together and go straight to the 5 second "LOW" delay. so my LED will flash once and then turn off for 5 seconds. I'd like to figure this out so I can use it in more complicated programs.
Can anyone help?
Try removing the semicolon from the following line.
Haha, yep that fixed it. Thanks! I just figured every line of code required a semi-colon after it.
Generally yes - but in this case the line of code is "extended", so to speak:
if (condition is met) { do stuff in here; } // so the line ends a little farther out, where the } is.
else {do stuff in here instead;} //and this part is optional, also ending where the } is.
Kemare:
It isn't lines, as C isn't line-oriented.
Statements require a semicolon after them, but statements can be recursively defined.
For example:
a = a + 1;
That's a statement. But you could write it as:
a
a
1;
Thus you can see that you don't just plonk semicolons at the end of physical lines.
Now an "if" statement is defined as:
if (<condition>) <statement>
So the semicolon goes after the whole "if statement" not the middle of it.
Notice how an "if" statement has a statement as part of it (this is the recursive definition). Thus the semicolon goes at the end of the whole thing, not the middle.
Fix this also:
If you mean to set FlashCount to zero, use "=" operator instead of "==", e.g.,
FlashCount = 0; //Resets the counter
Yeah thanks pekkaa, I figured that would cause a problem too.
