help with a BMs output and driving contactors ans ssr
hello
i am stuck, i have a 14s bms which only switches an output of 20 amps, dc. battery has a max of 51vdc and obvoiusly reduces
id like to drive something like a contactor or relay using the output but i am stuck
only way i can think is to use a voltage devider to reduce the voltage a bit, and use it to switch a relay or a ssd.
wondering if anybody knows of a pcb modual or another way i could do this?
thank you
(Note, Im not very well if my post dont make sense please be gently)
No, it doesn't make sense at all. Try using the shift key occasionally.
"BMS" = "battery management system"???
You are trying to make the BMS work on a higher current than the original 20A?
My first advice would be: "Don't do that. Buy the correct BMS to start with."
